I CAN'T hear dial tone from any of the handsets, AND CAN NOT call out or recieve calls. CAN NOT hear ringer because no calls are coming thru I guess/ All menue functions seem working- I CAN hear volume adjustments etc. All phones have always worked when set up(only using 3 of them)Everything just BAM wasn't working. Even tho I have phone company answering service that don't help me when I can't call it to check messages PLEASEEE HELP I already read the whole owners manual pftttttt DUMB DESIGN
SOURCE: Handset Won't Connect to Base Station
OK sorry guess I was thinking you had 2 handsets.
My suggestion is go to the Uniden website and maybe see what they have there.
Maybe do a search on the Uniden site for that Automatic Digital Security Code thing, seems it would be easy to fix, just a matter of how....
In the meantime I'll do some searching and see if I can help and find a fix
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
SOURCE: Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
