Unplug your power cable; Take off your casing cover; make sure your hand
is dry and clean, install your LAN Card to the right slot (Please refer
to your Network Card Manual Book); Power On your PC, Press Delete at
boot screen until u login the bios screen, go to the Advanced Tab on the
top there, Select [Disable] for Onboard Lan; Then save & exit.
You're done well! Congrat!
There is a solution to this. Buy a PCI LAN card and before you insert it into the computer, boot up and go into the BIOS and disable the
on-board network card and save the setting and shut down.
Insert the LAN card, boot up and install the LAN card driver and configure the LAN card as instructed by the ISP tech person.
