Question about Bosch HBN 452 / HBN 456 Electric Double Oven
My HBL452 double oven is slow to heat both upper
My Bosch HBL452 double oven is slow to heat both upper and lower oven. The unit is about 5 years old and we use only the upper oven and that about once per week.
The problem has been present for one month and the upper oven takes 35 minutes to get up to 350 and it takes some 15 minutes to get back up to pre-heat temp after food items are added. All the controls are illuminated and seem to function ok. We only ever use the bake function in either oven.
I have checked the circuit breaker box and the two oven circuits are mechanically connected such that both are on, or off together. There is no indication that we have lost one power phase.
  • Bosch Master
  • 43,501 Answers
If your electricMy HBL452 double oven is slow to heat both upper - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems My HBL452 double oven is slow to heat both upper - 2_bing.gifmg src="/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
6ya staff
SOURCE:
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Bottom oven not working
It is quite possible the control electronics have failed. There are separate relays for the upper and lower ovens. Ours recently failed the upper oven with the same symptoms and it was the electronic control. The other part is the overheat thermal sensor for the oven may be out.
Aug 01, 2008 | Whirlpool GBD307PRS Stainless Steel...
Inner glass door lower double ove
Many teasons for this to happen, no one has come up with a definitive solution for this,it just happens..
All you can do is have it replaced.
Mar 23, 2008 | Bosch HBN 455 Stainless Steel Electric...
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
Jan 31, 2008 | Whirlpool RBD305PD Electric Double Oven
Won't heat!!!
First, are the burners working right? It is possible that a breaker opened. Cycle your breakers off and then on. Its a shot....
How many elements in your oven? Sounds like one fried. Start the unit with the door open. See which element doesn't glow after a few minutes. Wait for cooldown, open the breakers and then remove it and take it to the appliance repair parts guy to test and replace. Funny...you should have gotten an error code.
Not that? It will likely be the thermister controlling your temp sense.
Dec 21, 2007 | GE Profile JT955SFSS Electric Double Oven
Bosch HBN 452 / HBN 456 Electric Double Oven Logo
583 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
