Kenmore dryer will not heat up to dry and would like information on troubleshooting the problem.
IT SOUNDS LIKE YOUR HEATING ELEMENTS HAVE BURNT OUT FIRST TURN OFF POWER THEN LOCATE THE SCREWS HOLDING THE BACK PANEL ON REMOVE THEM AND PANEL YOU SHOULD SEE THE ELEMENT REMOVE IT FROM THE PLUG I WOULD ALSO SUGGEST YOU REPLACE THE TERMOSTATS AS THE TEND GO THE SAME TIME OF ELEMENTS TAKE THEM TO A ELECTRICAL AND PLUMMERS SUPPLY STORE FOR REPLACEMENT REFIT TO YOUR MACHINE AND IT SHOULD WORK FINE , GOOD LUCK .
