That depends upon the IDE cable you are attaching the CD ROM to.
There are two IDE cables attached to the motherboard, on IDE 1 connector/cable will be your boot hard drive (C drive) and this will be jumpered to Master and you can attach the CD ROM drive to this cable and set the jumper on the CD drive as Slave.
On IDE 2 connector/cable if there are no drives attached to this cable then the CD ROM drive can be jumpered as Master or Slave..
If there is another drive on the same IDE 2 cable then look at the jumper on that drive, if it is jumpered to Master then the CD drive needs to be jumpered to Slave. If the existing drive is jumpered as Slave then the CD drive needs to be jumpered as Master.
Both drives on the same IDE cable cannot be jumpered with the same setting.
you might have to physically unplug the leads for this
cd/dvd then plug them back this should activate the found new hardware
wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
