Sony VAIO VGN-FS840/W Notebook Logo
Posted on Nov 30, 2009
Wireless network icon missing. Tried the recovery, but can not go through due to not being able to accessi386system32 toskrnl.exe
Anonymous
Level 1:
  • Contributor 72 Answers
  • Posted on Jan 04, 2010
Anonymous
Contributor
Level 1:
Answers
72
Questions
0
Helped
20326
Points
91
Go to control panel-wireless network connection-set the ICON
4answers
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
Missing <Windows
you need to do a restore form a restore point or full restore
<windows root>\system32\ntoskrnl.exe.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
4. Select the operating system you wish to fix, and then enter the administrator password.
5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
7. Type exit to reboot the computer.
Boot problem
Better open up ur case [while it is switched off],check the cables of ur HardDisk take them out and put them back again.Then also check ur RAM try pressing it a little into the slot.Solves my problem most of the time.
The intel proset wireless connection dissapeared
Do this when your system icon go missing.
(volume, network, clock & power)
CLEARING THE TRAY ICON HISTORY
> run 'regedit.exe'
> goto key 'HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \TrayNotify'
> delete keys 'IconStreams' & 'PastIconsStream'
> start task manager, go to processes and kill explorer.exe
> go to applications in the task manager, hit new task and type 'explorer.exe'
> explorer will now reboot and woohey, your icons should return.
1helpful
Driver installer doesn't install drivers. :S Gigabyte GN-WPKG
The problem could be caused,as you are also missing the chip-set drivers for the motherboard. You need to download and install the chip-set drivers for the motherboard first. Then install the wireless card driver and it would solve the problem.
Sometimes the conflict is also caused, due to faulty installation of the os.
1. Remove the entries of the PCI, from the device manager. 2.Remove the wireless card from the computer.
3.Restart the computer. 4.Shut down again, 5.Put the card back in and then install it one more time.
Thanks
Proton
Thanks
Proton
Recovery disk
Got this information from online technical support of compaq. You need to order the recovery disk online and need to provide the following details. Check out this link http://h18000.www1.hp.com/
  • serial # of your laptop
  • medel #
Or you can just install the operating system and device drivers. To download drivers click on this link http://h18000.www1.hp.com/cpq_support.html and key in your product number (this is found under your laptop)
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
