Vacuums Logo
Posted on Nov 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me thank you
Anonymous
Level 3:
  • Master 701 Answers
  • Posted on Nov 30, 2009
Anonymous
Master
Level 3:
Answers
701
Questions
0
Helped
298310
Points
1875
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
2answers
Hoover spinscrub 50 smells like rubber burning
There are no belts lol. Its a carpet shampooer
Electrolux cylinder vacuum No suction and loud noise and smell of buring rubber
rollers are probably stuck the belt is burning check for restrictions in you hoses as well as in the vacuum as well if nothing else works a repairman
Jul 13, 2012 • Vacuums
When i plug it in it makes a loud noise and produces smoke. that smells like something is burning
SOUNDS LIKE YOUR BELT IS BURNT OUT, YOU'LL NEED TO TAKE OUT AND REPLACE. Try Sears for this part. An inexpensive part.
Dec 07, 2010 • Vacuums
2answers
Burning smell from motor
Check your filter and also check that nothing got pulled into the motor...otherwise the motor is burning up and will need to be replaced... probably cheaper to replace the whole vacuum..
heatman101
While starting my vaccum cleaner big noise and stream is coming . it is dead?
No Brand? I think you mean big noise and smoke? Smoke can be from a burning belt or dying motor. If it smells like burning rubber you likely have something jamming the brush roll. Otherwise suspect the bang came from a motor fan. Do not attempt to run. disassemble and inspect
Aug 19, 2009 • Vacuums
2helpful
1helpful
2answers
Loud noise and smell of rubber over heating
sounds like you have something stuck in the beater bar/roller and the belt is slipping. You're probably going to have to take it out and replace the belt. Also check for wads in the passages.
3helpful
2answers
My Bissell Cleanview Bagless vacuum makes loud grinding noise.
the ends of the roller have something wrapped around them.see if you can pull the ends off so you clean the caps and bearings
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
