Driver door won't close 1999 ford contour
Drivers side door will not close because, it might have dropped out of alignment and is sagging down slightly!!! or if it has electric door locks, and someone in the family has failed to mention door locks were activated while that one door was still open!!! now lock mechanism has passed it's normal stopping place and is now stuck, therefore already locked and not allowing door to close all the way!! you might try disconnecting battery then try jiggling the lock, and hope silenoid didn't get burned out, open passenger door and look at lock latch, then check drivers side lock latch!!! if your lucky lock latch should unlock when battery is hooked back up. i have seen this problems happen often on older vehicles!!! especially on cars or trucks that have been in fender benders.........body shops know what to check for, they fix problems like this often!!!!! Good luck!!
