Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
Posted on Jan 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony TV Screen
I have a 55 INS Sony TV. Flat Panel rear projection
The TV is over one year old.
Half of the TV has green back ground and the other half is showing the correct color.
It shows green even with Black and white shows.
I installed a HDMI cable.
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Jan 15, 2008
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1710957
Points
8129
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
I have a 55 in HP TV and has power, when i press the on button the light turns blue but no picture THIS IS A FLAT SCREEN TV 55 IN.
get it fixed, call a service tech or take it in to a shop.
NO model TV stated at all just TV (HP)
HP LD5511 55"(this?) or some old plasma TV? what model is it , thanks.
on the rear is a tag that tag shows the model
first is age, how old is it and models tell me that.
the early LCD TV have back lamp that go out.
is sound dead, too? if yes, the TV has a bad internal power supply.
if sounds good but screen is dead, (use a flashlight pointed at the screen see video now (weak sure) but if seen that tells you the back lamps are burned out. (did TV screen run hot for many years )
yes, those are the ones that burn out.
here is the model prefix letter decode rules on HP TV.
  • PE or PL = Plasma TV
  • LC = LCD TV
  • LT = Professional Flat Panel LCD TVs
  • SL = MediaSmart LCD TV
  • MD or ID = Rear Projection Microdisplay TV
as you can see TV means Little. lacking full model numbers.
1helpful
Sound but no picture. No prior problem.
Replace video board. That fixed mine and not hard to replace.ordered mine on e bay. Lay TV flat on something soft so not to scratch screen and remove back. A few screws and a few plug ins. Remove old card install new one. Pretty much plug and play.reinstall back cover. Done.took me about 30 minutes.
My sony grand wega 55 constantly will turn off picture and sound, green lamp light stays green and then after about 30 seconds the picture and sound return, it has the original bulb in the tv and is around...
The LED light "LAMP" indication stay on or flashes in this problems?Yes,the projection lamp is the causes and problems.Change the projection lamp,should solved the problems.
4helpful
Green light blinks and eventually turns solid green but only black screen no picture
When did you replaced lamp last time in tv?
If lamp has not been replaced in last 2-3 years then its time to change lamp.
Buy Sony original lamp for good picture in tv.
I have a sony lcd 55" flat screen. We have blue dots in the center of the screen multiplying every day. What causes this exactly. Is it cost effective to repair ? Could I repair it my self ? I have basic...
model # says its a 42" sounds like a rear projection lcd tv not a flat panel its your light engine sony will replace it free if its less than 5 years old
Tv does not stay on
If you have a rear projection, it is the bulb. Ypou need to replace it.
1helpful
2answers
Big screen TV corners of tv blue and red
I HAVE A 57" TOSHIBA REAR PROJECTION TV. HALF THE SCREEN HAS A BLUE TINT AND THE OTHER HALF IS CLEAR.
2answers
Sony KF-50WE610
the color drive is going bad check with the sony service center it might be cover and repaired free.  my set went blue and the service tech is checking if it is covered.  good luck.
Green screen...
Probable bad green CRT..........usually about 600.00....T.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
