If electrical ( the motor shuts down like you turned the key off) its likely the rider presence switch ( seat switch).
If the motor is pulled down and dies as if its uncapable of handling the load check the drive system. Remove deck and check drive belt and pulleys. Pull the belt off of a pulley for slack and with the tranny in first and the brake released you should be able to turn the large pulley on top of the tranny easily which should cause the tractor to start to move. If you cant turn the pully there is something wrong in the tranny.
