How to reset computer to factory settings on a acer aspire 6920 G need to wipe compter clean
  • 742 Answers
You need to reload everything from your Recovery Disc. Do you have a recovery disc? If you don't have, just format your hard drive and re-install your OS. Install your motherboard drivers from the CD you have when you first bought it. Also, reinstall the programs you have. In this way, you have everything fresh like brand new.
Posted on Nov 30, 2009
6ya staff
SOURCE:
Acer aspire 6920 factory reset
Use the following steps to restore the your computer to factory defaults.
  1. Press and hold the Power key for 5 seconds to power the system off completely.
  2. Press the Power key to turn on the computer.
  3. Press the Alt and F10 keys at the same time when the Acer logo appears on the screen. ...
  4. Select Troubleshoot.
Oct 07, 2018 | Acer Computers & Internet
I need to know how to reset my acer aspire 6930 to factory settings!!!!!
A slightly different model requires pressing Alt+F10 at the start up and following the prompts. This will wipe the hard drive though, so back up everything important first. You can probably still get the data even if it doesn't boot Windows.
Mar 17, 2011 | Acer Aspire 6930-6771 Laptop
Reset acer aspire one d255
Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer.This will RESET the computer to its Factory Settings( DATA LOSS )
To start the system recovery:
  1. Restart the netbook.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
Oct 21, 2010 | Acer Aspire 6920 Notebook PC
Need to reset my acer computer to factory settings.
Hi! Try system restore first and check if that will remove the virus but if not then you can reset the machine to factory defaults by pressing ALT+F10 during start up or when the acer logo appears on your screen.Follow the prompts and you should be able to reset the computer to factory image.Make sure you back up important files because it will wipe the system clean.hope this helps...
May 29, 2010 | Acer Aspire™ T180 PC Desktop
I bought the Acer 6920 factory restore CD's to set it back to factory default but when i run it it gets to the third disk at 90% and then says Restore Failed and gives me this Error code 0xd000000a. Does...
It stands to reason that if it ran the other 2 it should run all of them. that tells me its probably not your system. The disk could be faulty. I would check with manufactuer.
Apr 05, 2010 | Acer Aspire 6920 Notebook PC
I have an acer aspire 6920 laptop and i am trying to do a system restore but not have a disc, wat can i do
Reboot the system and on restart press the F8 key to access the advanced system options. Select repair my computer to start the system recovery partition.
This option will restore the system to factory settings and some files or programs will have to be reloaded.
I’m happy to help further over the phone at https://www.6ya.com/expert/walter_628d4d23d01fb34d
Oct 31, 2009 | Acer Aspire 6920-6422 Notebook
Acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 22, 2009 | Acer Aspire 6920 Notebook PC
Passwords
you can try to remove the battery from the motherboard this usually resets passwords.
May 11, 2009 | Acer Aspire 6920-6621 Notebook
Acer aspire 6920. needs to be reset back to factory settings
use a recovery cd/ dvd if you have , boot your system to this cd then follow the instructions
Nov 23, 2008 | Acer Computers & Internet
Open Questions:
Computers & Internet Logo
290 people viewed this question
Ekse
Marvin
Marvin
