Questions: You are so excited to the large capacity and nice sound quality of Sansa player, yet you are confused to put your favorite videos to your Sansa Fuze, Sansa View, Sansa MP4 Movie and other Sansa players.
How to convert MP4, MOV, M4V, AVI, FLV, SWF, MPG, ASF, WMV, MP3, AAC, M4A etc. to Sansa media player? This guide enables you to full enjoy on your Sansa MP3 and Video player by Sansa Video Converter for Mac.
Solution: step by step guide to enjoy music and video on Sansa media player.
Preparation:
Software: Doremisoft Sansa Video Converter
System Requirements: OS Supported: Mac OS X v10.5
Hardware Requirements: 512MB RAM, Super VGA (800×600) resolution, 16-bit graphics card or higher
Download Now
Step1: Connect your Sansa video or MP3 Player to your computer through the USB connection.
Step2: Download Sansa Video Converter for Mac and run it.When you have installed this Sansa Video Converter, it will pop up the screen like below.
Step3: Add Video or audio files to Convert.Click "Add File" button to load your videos from your computer. Select the video files you want to convert. Also you may preview your video by clicking the left play button.
Step4: Preview and Select Click a file in the List or select several files. You could preview videos to play the file.
Step5: Edit the video with the function button:
Clip(Merge, +/-), Edit(Crop, Effect, Rotate), Settings(1)Clip: You can cut your long videos into small clips or get more than one segaments just clicking "+/-". Besides, merge two or more video files into the whole successive one.
(2)Crop: This function helps you cut off the undesired area from your movie video and choose your favorite clips to convert.
(3)Effect:In the "Effect" selection, You could tune the Brightness, Contrast, Saturation and Volume to get special effect movie, in addition, you can Select Emboss, Gray, Old Film effect from Special Effect.
(4)Rotate:Change video play direction in180, horizontal or vertical way to watch videos.
(5)Settings:If you want to customize the output video’s quality, you can click the "Settings" button to open the settings window and set video Resolution, video Bitrate, Audio Channels, Audio Bitrate. Also, if you do not set them, the software will use the default setting to convert.
Step6: Select the format for your Sansa files. You may select "
Sansa Video MPEG-4 (*.MP4)".Tips: This format is to generally use. If you want to convert your videos into portable players you'd better select format according to your player. Then the output videos would be much more compatible with your player.
Step7: Start to convert the files.Check: Click the right convert button. The converting process will begin. Please wait before the converting successful in a few seconds.
Well done. Now you can enjoy your favorite music and videos on Sansa player everywhere.
