Not charging please help me .my mobile is not charging, when cable is connceted to charge display is seeingits charging then connection is discharge there is no charge in mobile.
Connect the charging cable to your tracker and plug the other end into a USB port
Press and hold the button for around two seconds and deprived of letting go of the button take away the charging cable from your tracker
Wait about six to ten more seconds after removing the charging cable discharge the button and keep holding it down again
Once "ALT" and a white screen flash, discharge the button and keep holding it down again
After you feel a vibration, discharge the button and keep holding it down again
As soon as you see "ERROR," discharge the button and keep holding it down again
As soon as you see "ERASE," discharge the button. The tracker is going to turn off
To about-face your tracker aback on, essayist the button or attach the charging cable (make abiding by bung in the added end of the cable). When you can see the time on your tracker is 0:00, you have successfully reset your device.
Next, you'll tell your Fitbit account that you're setting up a new tracker
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
There might be some battery issue you need to replace this battery to another one and please don't left your mobile while you are charging battery cells going to dead if its over charge and you will going to lose your battery and mobile as well Laptop Rental Laptop Hire in UK Wales Ireland and Scotland Hire Laptops
Secend Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
i had the same the issue due to my ipod. the problem that i think is with you is that you may have done something. To get your ipod on again hook it to the computer (USB cord) and re format it. that means you would have to clean your drive completely.. dont worry!!! then you need to put songs all over again...
Hai dud,
A battery maintenance system for charging, analyzing, discharging and conditioning of a NiCad battery. The system displays voltage and capacity to determine whether or not a NiCad battery has enough capacity to power equipment for an optimal time period. The system charges the battery using a negative delta voltage method of detecting full charge, while also displaying instantaneous battery voltage. The system also analyzes the battery in a charge, discharge and recharge mode of operation, and during the charge mode the instantaneous voltage is displayed. The discharge mode discharges the battery to one volt per cell while displaying voltage and accumulative capacity alternately. The system also conditions batteries by cycling a battery through three cycles of charging, discharging and a subsequent recharge cycle. Hope it Helped You!
USB cable is connected between PC and Mobile, Charging is happening. Modem drivers installed. Mobile phone is displayed having Sychronising, phone book, calendar, text message, multimedia studio. On this "initialisation....please wait" is displayed and after some time it displays "mobile not connected".
