Low or no water supply, hot or cold side or water pressure switch not switching over to indicate fully filled though if this happens drain motor will continue to run continuously while f-20 flashes
ok usually this means a no or slow flow of water coming into washer..the hose could be kinked, or the screens clogged, or someone turned off the water valve slightly or the valve itself is going bad
This is a Long Drain Issue. Likely that something is stuck in the pump trap. Take off the mottom tree screws under the drum panel. This will remove the drum panel on the front. From under neither you can see the drain pipe trap. Unscrew the trap cap in the from. Clean out all debris and re-install. this should do it.
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Error F 20 means "No Water Detect" error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
You'll need to check for the following--
1- Check the Inlet water valve if it is clogged.
2- Make sure water taps are working fine. 3- Check inlet hoses for kinks or clogs.
Please do rate this solution as FixYa and revert for further assistance.
The electronic control board is damaged. It needs to be replaced. I think its Part#8182237. As of this date, it is on back-order. Check your warranty
book on this part, it is highly expensive. It may be covered under a
2-5 yr. part only warranty.
You can wash Shoes in it... But the manufacturer does not recomened it.. I would suggest that you remove the laces and you should be just fine
good luck
Kenmore 5T he Elite diagnostic mode
