Motorola Talkabout T5000 NiCd Two-Way Radio Double Pack Logo
Posted on Nov 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to silence the roger beep but forgot sequence
eradiostore
Level 3:
  • Motorola Master 1,672 Answers
  • Posted on Nov 30, 2009
eradiostore
Motorola Master
Level 3:
Answers
1672
Questions
0
Helped
796664
Points
4248
To turn on or off the "roger" beep hold the plus (+) button in while turning on the radio.
Best regards.
1helpful
How do you silence beeping after you press ptt button?
Hold the + (plus) button in while turning the radio on to turn the Roger Beep on or off. Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf The instructions are on pg 25.
Best regards.
What does 4 Short beep, 1,5 sec silence, short beep, 1,5 sec silence, 1.5short beep, 1,5 sec silence, mean and hoeto fix
most acers use phoenix bios chips.
Here is a list of the beep codes.
reference yours to this webpage
http://www.bioscentral.com/beepcodes/phoenixbeep.htm
as soon as you have found the corresponding codes you can place it here for us and we can then proceed from there.
2answers
Short beep, 1,5 sec silence, short beep, 1,5 sec silence, short beep, 1,5 sec silence, short beep, about 3 sec silence and then complete shutdown
There is a problem with the laptop that is why you get the short beeps and then it shuts down.
The problem mainly is that, the components in the laptop are not sitting well or there is a faulty component in it. So it is not able to run a full loading of the operating system.
Have a repair man assess the RAM and other components in the laptop like the Hard disc and the rest. Remove them and install them back in.
Any fault detected should be corrected.
Take care
How do I silence the beeps on this radio
There are two features which cause the radio to make a tone or beep, before or following a transmission: Talk Confirmation Tones (aka Roger Beep) and Call Tones.
On the T6510 radio you would hold in the + (plus) button while turning the radio on, to turn ON the roger beep. To turn it OFF you would hold in the - (minus) button while turning the radio on.
Call Tones are a little more detailed explanation. You can find directions for both in the user guide on page 25: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Best regards.
How do you go to silent mode?
There are two different kinds of beeps you can control, the "roger" beep and the "button" beeps. Below is an excerpt from the owners manual explaining the simple procedure.
“Roger” Beeps/Talk Confirmation Tone
When you turn this feature On, your two-way radio transmits a unique tone when
you finish transmitting. It’s like saying “Roger” or “Over” and lets others know
you have finished talking. If the person you are talking to does not hear the talk
confirmation tone, you can enable it by pressing and holding + (plus) as you turn On
your radio. Now, whenever you release the PTT, you let your friends know you have
finished talking by transmitting a “Roger” Beep tone. “Roger” Beeps will be
disabled as the Default Setting.
Note: To toggle the Talk Confirmation Tone feature, turn your radio Off and then
back On while pressing and holding + (plus) .
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press - (minus) and
hold . To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the - (minus) . On is the Default setting.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T7100_User_Manual_E.pdf
17
2answers
Motherboard
TAKE YOUR DDR CARDS OUT ,, AND SWITCH THEM,, ,,IF THAT DOESNT WORK TRY WITH ONE AT A TIME,, GOOD LUCK
2helpful
Motorola radius sp50 "roger beep"
The radio will need to be reprogrammed using the radio service software for the SP50 radio.
3helpful
Roger tone
Hi, To remove the "Roger Beep", power off the radio. Press on the "+" button, without letting go, power on the radio. Release the button. The "Roger Beep" should be gone by now. To activate, do the same. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
