Your motor is going bad if it get's that hot. It is kicking off when it get's hot enough to the heat switch in the back of the motor. This resets it self and the motor probally comes on again after a few minutes. The wireing in the motor has a small short that will get worse soon enough and may even catch fire if the conditions are right. So you should get a new one and replace your seal kit and "O" rings at the same time. Odds are a small water leak got this started. Good luck
1.Pump not primed
2.Leakage of air into suction system
3.Impeller clogged
4.Valve in suction or discharge line partly closed or suction or discharge line partly plugged or too small. 5.Plugged basket in skimmer or hair in lint strainer.
6.Dirty filter.
