Mitsubishi WS-65615 65" TV Logo
Posted on Nov 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The TV only shows a royal blue screen. I can get
The TV only shows a royal blue screen. I can get set up menus but no picture.
David Low
Level 3:
  • Master 458 Answers
  • Posted on Nov 29, 2009
David Low
Master
Level 3:
Answers
458
Questions
Helped
138761
Points
1304
This would appear there is no incoming signal. Check your antenna or cable connection is connected securely & then try to retune the TV once more, you should pick up a picture. If not, if you have a DVD connected via a scart, check if you receive the DVD picture. If this is the case then there will be a problem within the tuner stage, possibly a replacement tuner will be required
The picture will not show up on my tv screen. It is a Hitachi 65f49a, the menus will show up but the picture will not.
try different inputs on the set and check to make sure with the remote you are on the one you are connected to
My screen is green and does not show a picture or sound! You cannot change the channel or access the menu! Is it the picture tube or lamp?
Can you see menus if you press the menu button? You could be set to the wrong input that doesn't have a signal coming in. I have one TV that shows a blank blue screen when I'm on an input that has no signal. If there is not a signal on the input being used you will also not have sound.
1helpful
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
2answers
SONY BLUE RAY ONLY SHOWS IN SMALL SQUARE. THE
Have you gone through your TV's menus? You may have to change screen resolution from within the TV's settings to get a full screen presentation.
2answers
Bush tv 20" lcd tv LCDS20TV006/A - blue screen no picture availab
DOES THE MENU SCREEN COME UP? IF YES TRY ANOTHER INPUT. A BLUE SCREEN IS USUALLY INDICATIVE OF THE SET NOT SEEING A VIDEO SIGNAL.
1helpful
2answers
RCA F32665 Shows only gray screen, sound works.
You have a problem in the video circuit. Any video that comes into the set is not getting to the picture tube. The menus come from the system control microprocessor. This shows that the input at the picture tube itself is working. Also you system control is working. The signal would have to be traced through the set to find out where the loss is originating. Stargazer
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
