the Jaguar does not have a electronic water poump, only the x350 xjr has a auxilary coolant pump for the supercharger.All x350 xj8 models have a conventional water pump.
Having a restoration shop and running several newer Jaguars I have seen similar situations. Intermittent multiple errors such as these can be caused by a low battery (or corroded connections) that "fool the computers". Also had a '99 XJ8 VDP have exactly the same issues over several months. Issue was a manufacturing fault in the sensors on the throttle body that caused the "limp home" mode - usually in stop and go traffic. Jaguar had an inspection and recall on the throttle bodies but that vehicle had gone through 3 different Jaguar dealers for service and none looked at TSB/Recall or performed the necessary checks on the throttle body. Tried cleaning the throttle several times (per Jaguar TSBs) but no change. Had to replace throttle body & problem solved (over 30,000 miles since then). Recommend making sure all air connections to throttle are clean and open and cleaning the throttle area to see if that helps.
On newer Jaguars (and other Al bodied cars) similar problems occur when the "ground" connections to the body become poor (usually through corrosion but sometimes through collisions). Connections may look perfectly normal but have high resistance. Careful when working with the connections - the posts are usually very loosely fastened to the bodies. The engine quit on a 2005 XJ8 VDP when I turned the wipers on (fortunately I was driving slow in a parking lot) because one of the forward bulkhead ground connections was corroded (looked normal but separated from body when removing the wires to clean them).
Also there occur occasional funny intermittent issues with all newer Jags that seem to be untraceable and non-reproducable computer "glitches".Good luck.
This is very common, because your battery is dead your remote isnt going to work. So what you have to do is look by the license plate light bulbs, their is a key hole wear you can insert you key and open the trunk to charge/ or jump start your battery
the battery has gone dead you can not open the boot/trunk with the electrical system but you should be able to get to the battery by using the key in the lock on the outside of the the trunk its either in the xj badge or the number plate illumination holder. if you can open the engine compartment there is battery pos power points so you can jumpstart/power up the car
