Samsung   YPZ5FZB 1 GB, BLACK, MP3 Player, 1.8" 262k ColourTFT, Flash Memory, USB2.0 Host, D... MP3 Player Logo
Posted on Nov 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a samsung yp-z5f but i can't get in menu and it keeps freezeing.i reseted it but sill nothing.can you help?
Adnan Bhatti
Level 3:
President:
  • Master 1,188 Answers
  • Posted on Nov 29, 2009
Adnan Bhatti
Master
Level 3:
President:
Answers
1188
Questions
Helped
410236
Points
3822
A firmware upgrade may solve the issue. To upgrade firmware follow these steps:
  1. Download the firmware file from the Samsung Download Center by clicking here.
  2. Remember to save the file to your desktop or documents.
  3. Uncompress the downloaded file in a folder (use winrar or winzip). DATA file will be displayed.
  4. Connect the player to your PC with the USB cable.
  5. Right click on the Start button, and then left click Explore to open Windows Explorer on your PC. [Samsung YP-Z5] is displayed in Windows Explorer.
  6. Select the uncompressed files and drag-and-drop it into the Samsung YP-Z5 Data folder.
  7. Disconnect the YP-Z5 from your PC. After disconnecting the USB Cable, the upgrade screen appears.
  8. Select [Upgrade] to upgrade firmware.
Try it and see.
My computer does not recognise my samsung YP-Z5F player at all,i am running windows vista,what should i do?
Manual for YP-Z5F:
http://downloadcenter.samsung.com/content/UM/200605/20060511090848406_YPZ5F-COMMON-ENGLISH0.0.pdf
1. Try a system reset: page 60
1.1 Turn the power on
1.2 Press the Reset hole on the bottom of the player.
86a5bae.jpg 2. When power won't turn on: page 61
2.1 Let the player charge
2.2 Turn the power on
2.3 Press the Reset hole on the bottom of the player.
3. Windows update might be required: page 63
3.1 Press <Start> on the toolbar of your PC to run Windows Update.
Select Key Updates and Service Packs, then update all.
Reboot your PC and reconnect.
When you're connecting to a pc that has another Operating System:
1. Install the software matching for your OS on the computer.
2. Update your player withe the latest firmware if available.
Note: when reinstalling firmware all files (music, pics, videos) will be erased from the player.
Downloads support page:
http://www.samsung.com/uk/support/main/supportSupportMain.do
Entering your exact model will lead to the correct downloads.
1helpful
Problem of frezzing and non asistance for my samsung tp-t9
Look sir.The yp-t9 has a minor problem of freezing.When it freezes just press the rec button and menu button together this would reset your yp-t9.This will help.
Yp-z5f MP3 PLAYER
i can't change my samsung mp3 YP-Z5F 2 GB and i don't have installation CD.So,how can i change and where can i download installation CD,If you don't mind , you can give me that CD,My account is [email protected],
thanks you!~
MY SAMSUNG YP-Z5F-PLAYER FREEZED!
Hi there. Have you tried the reset procedure, by pressing the tiny button under the player with a paper clip, or a pen's tip ? That might do it ! Please reply if it doesn't work, and give a bit more details on the exact player's behavior :) Thanks, cheebster.
2answers
Samsung YP - Z5F
Samsung YP-Z5F
Will not always switch on and when it does switch on will not respond to control panel
It wont turn on to the main menu, it only says samsug
use the USB cord, then plug you mp3 into the computer, in a few seconds the welcome screem will be showing, then you let the mp3 charge, then it will work properly... that's what happened to me
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
