Question about Olympia CDP 24201 Cordless Phone
There is sound for the ringer. any solutions?
There is no sound for the ringer. both call display and the phone ringer does not work when i receive incoming calls but if i pick the receiver, i can talk to the caller. it is very strange, i do receive the calls but the call display and the ringer does not ring and show. any solutions?
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: My Olympia cdp 24201 has no sound i called it from
you just need to take the battery out and wait 30 seconds, replace it and it should be able to find the base. i had this problem and called olympia and this is the fix they gave me. It's worked for 4 years!
Posted on Dec 08, 2009
guru_fixya
Natarajan Ramasamy
  • 944 Answers
SOURCE: My globe will no longer
Your unit has some settings problem.You have to reset the unit.Try resetting the unit.If still the problem persist you have to reset the infoGlobe.txt file using PC interface cable.Which they will do in service centre only.
http://www.lima.com.tr/BasicTiger/Applications/PDF/appn_071e_The%20magic%20globe.PDF
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 10, 2011
Low volume on incoming calls
remove battery from phone and reinstall after 10 mins... this seems to fix alot of things also go to sound setting a make sure the volume is turned up all the way
Jul 09, 2012 | Apple iPhone 3G
Ringer ploblem
try using it on speaker phone. i have the same trouble on a panasonic cordless hand set and it only works with speaker phone turned
Nov 25, 2011 | Samsung C5212 Cell Phone
We have a Panasonic KX-T7433 telephone at work but 2 of the phones do not ring when we have a call we have to go and pick up the main phone at the other end of the room. We can call out on the phones but...
From the phone, press intercom and dial 790. That clears any "cleaning person" button presses. Check the ringer control button on the left side of the phone to make sure it's on. The "we can't pick up the call" is disturbing because the line should appear on your phone. In a TD system, the lines are normally numbered 01-12, but that's on this side of the pond. If you have ISDN ot EI trunks, they may be different. In a standard key system, the line buttons are called Single CO (SCO) buttons and are programmed by prressing Program 99 on an idle phone, then the button and reading them. If they don't say SCO 01 02 03 etc, you dial 0+01 02 03 etc STORE to change them.
Pick up the handset and drop it back down when you're finished.
Carl
Jun 30, 2011 | Panasonic KX-T7453 Corded Phone
How do I turn off the ringer on my AT&T 832 telephone? I do not see a ringer button and I do not have a manual. The phone is about 12 years old.
Hi
You can turn off the ringer completely so it no longer makes an audible sound when the phone receives an incoming call. The phone's ringer options can be accessed in the handset's menu.
Press the "Menu" button on the phone.
Press the up or down arrows until the phone's display says "Ringer Volume."
Press the "Select" button on the phone.
Press the up or down arrows until the phone's display says "OFF."
Press the "Select" button to save your settings.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 14, 2011 | Cell Phones
Message box says, "ringer off".
Ringer Settings
Handset ringer volume
4 levels (high/medium/low/off) are available. The default setting is HIGH.
1. Press "Menu."
2. Scroll to "Ringer setting" by pressing up or down arrows.
then press the arrow that looks like a play button arrow pointing to the right.
"Ringer Setting"
3. Scroll to "Ringer volume" by pressing arrow down or arrow up, then press the play button type arrow.
4. Press arrow down or arrow up repeatedly to select the desired volume.
5. Press "Save."
(To turn the ringer off, press down arrow repeatedly until "off?" is displayed, THEN PRESS "SAVE.")
Here's the manual:
http://service.us.panasonic.com/OPERMANPDF/KXTG2431.PDF
Please give me positive feedback if this helps you.
Thanks.
Feb 23, 2011 | Panasonic KX-TG2431 Cordless Phone
I can't turn on the ringer on my AT&T BIS-10 Merlin phone. My line blinks green when a call is incoming and I have to pick up and press the button in order to receive the call. I need the phone to...
Depends on what system you have that phone installed o.
If Merlin Legend, on the left side of the phone there is a 3 position switch. Its in the middle position now.
Slide that down
press on of your lines
Press *347
Slide the switch to the middle position.
If that doesnt work, we need to know the system you have these phones on.
Aug 24, 2010 | AT&T Merlin BIS 10 Phone
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
I9+ phone will not receive incoming calls
check and make sure you ringer is set to something but silent.
Jun 04, 2009 | Cell Phones
Motorola v3i
you would have to saved the contacts on your phone memory then assign ringer id to them and pics as well.
Nov 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Olympia CDP 24201 Cordless Phone Logo
Top Olympia Lands Phones Experts
ray gallant
ray gallant
Jose Ma DM.
Jose Ma DM.
Tom Chichester
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
