The power button got jammed and i fixed it but now it wont charge or turn on and when i hook it up to my computer the blue light flashes and nothing happens
Connect the player to a USB port on the back of a desktop PC..
Check the display for the charging icon .
As the display times out after a few seconds, press any button on the player to reactivate the display.
If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is blinking on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
You might try updating your ZEN V or ZEN V Plus firmwareto take advantage of new features and functionality.
http://support.creative.com
If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
Creative recommends updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality. To learn more, visit SID 29048 in our "Further Suggestions". Note: If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
Reset pin on the left side with the player facing up.
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging. posted on Feb 25, 2009
abeales
If
you have windows set to do automatic updates, you most likely had a
windows update installed that caused this conflict with Win Media
Player 11. No fix has been posted by Microsoft yet, so the only
workaround is to Uninstall/Rollback Windows Media Player 11. Goto
<Control Panel<Add/Remove Programs and remove Windows Media
Player 11. Follow prompts, restart computer when prompted to. Also
uninstall Windows Media Player 11 Runtime application following same
procedure above.
This will roll your Windows Media Player back to version 10 or 9,
whichever you had installed prior to version 11. You will need to
re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You
probably need to upgrade your firmware at this point, follow the
instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative
for the screwed up hotfixes that Microsoft puts out on a regular basi
Creative Zen
Try another PC or another USB port
Make sure the hold/lock is not engaged
Reset
Check for firmware update on Creative's website
Get Recovery Tool from Creative
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If all else fails, check with this guy:
http://www.mycreativefansite.com/2007/05/myzenchecker-tools-guide-to-problem.html
Creative Zen – Formatting
Step by step instructions for formatting a player
1. Detach the player from the PC if it is connected, and turn off the player.
2. Press and hold the Play button while powering on the player.
3. When the player displays the Creative logo, release the Play button
4. Select Format (All) and select Yes to format the player.
5. After the player has finished formatting, select Reboot.
6. Re-transfer the tracks to the player.
-Tha Mp3 Doctor
Before plugging the player to the computer, turn it off,hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. It worked for me ! GOOD LUCK !
If that doesn't fix it trythe USB cable Screen Doesn’t come on anymore http://www.anythingbutipod.com/forum/showthread.php?t=18859 If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Zen V is dead "If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
