Xerox DocuColor 12 Printer Logo
Posted on Nov 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm trying to install a c4380 wireless printer with windows 7 but it won't take, says it's not supported by software
Christopher Thrash
Level 3:
  • Master 425 Answers
  • Posted on Nov 28, 2009
Christopher Thrash
Master
Level 3:
Answers
425
Questions
Helped
107706
Points
1354
  1. First find out if you are using 32 or 64 bit
  2. Click Start
Collapse this imageExpand this image i'm trying to install a c4380 wireless printer - vistastartbutton.jpg , type system in the Start Search box, and then click system in the Programs list.
  1. The operating system is displayed as follows:
    • For a 64-bit version operating system: 64-bit Operating System appears for the System type under System.
    • For a 32-bit version operating system: 32-bit Operating System appears for the System type under System.
Method 2: View System Information window loadTOCNode(4, 'moreinformation');
  1. Click Start Collapse this imageExpand this image , type system in the Start Search box, and then click System Information in the Programs list.
  2. When System Summary is selected in the navigation pane, the operating system is displayed as follows:
    • For a 64-bit version operating system: x64-based PC appears for the System type under Item.
    • For a 32-bit version operating system: x86-based PC appears for the System type under Item.
  3. Then go to hp website and download driver for windows 7 for correct bit version.
  4. Unistall old driver install new.
I hve windows 7 and am trying to set up brother mfc-665cw wireless is it supported
Try installing the software that shipped with the MFC. If you have problem installing the software on Windows 7, you can go to the Brother Solution Center and download the latest version. If the Optical character Recognition software is not installed with the suite downloaded from the web, you will have to use the CD shipped with the machine to install it.
You will need to use the software to add a new printer to your network.
How can i download the drivers to enable me to install hp photosmart c4380 on to my hp laptop with windows 7 free.
just go to manufacturer site and find the download for windows 7 driver or just google it.
2answers
HP C4380, Wireless Printing Problem
Do you have other printer drivers installed, if so thre may be a driver conflict. wireless printing requires network connection and also printer drivers. This appears to be a driver issue since the printer shows up on the network. I would try reinstalling the drivers.
Can my HP Photosmart C4380 support Microsoft Office Professional 2007 Fax and Scan? Or must the HP fax and scan only be used?
Sorry, Fax and Scan is part of Windows Vista not MS Office. I have been advised by PC World team that this printer (HP Photosmart C4380) does not have the necessary drivers to support Vista Fax and Scan wirelessly and can only operate with the HP Fax and Scan which is very basic and only seems to function via USB cable, not wirelessly. Update drivers may become available.
Photosmart C4380
delete the old installation and reinstall the printer again and do the reconfiguration for either USB or wireless. It worked for me when I did this. The scanner begins to work and no more 'no USB or wireless connection' msg anymore. :~)
1helpful
Trying to instal photosmart C4380 all in one wirelessly on toshiba L40-17M from supplied disc installed printer ok first time but scanner not recognised, scan button says computer connected but computer...
Photosmart C4380: good hardware, appalling software. Shameful that it's on the market at all.
WIRELESS PROBLEM
You have to install the printer as USB first. Then, once it's all installed, load up the CD again and 'Add device', choosing the wireless option. It's crucial that you leave your USB cable in the whole time. Take it out right at the end. Once you've added a device, you'll have two printers installed. One will be called 'Copy 1' - that's the wireless one. It should all work okay, and you can delete the USB one.
SCAN PROBLEM AND ERROR MESSAGES
When I did this everything seemed to work fine. BUT - after a wee while the software started playing up. The scan function didn't work at all, HP was depositing all sorts of bugs all over my computer, I had error messages coming up at shutdown, all sorts of gremlins.
So this is what I did.
I totally uninstalled all HP software.
I downloaded the updated Photosmart Basic Drivers from the HP website. They are here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3221646&lc=en&cc=us&dlc=en&submit.y=11&submit.x=9&lang=en&cc=us
Once you've downloaded the file and run it, the new drivers will be installed but NO SOFTWARE. Again, you have to do the whole setting it up as USB and then leaving the cable in and adding the device wirelessly. But if you do this with the HP drivers and ignore the installation CD, then everything should work perfectly.
Of course this means no HP software at all. But who needs it? I use Microsoft's scanning software, which is fine, and it has no problem printing.
Basically HP's software is BLOATWARE that doesn't even work. It screws up your computer.
Good luck!!
Hp photosmart c4380
well..you'll need a different set of drivers for vista
get them here(make sure to choose vista for operating system)
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
