99.9999% of All Cordless drills (unless they are made in Tasmania!) DO NOT have a Key-Tool or "chuck" to tighten; Drill bits, Driver bits, etc. Simple...Solution! Hold drill naturally with right hand extended Out and elbow at your side. Take the Palm of your left hand and place over the drill part that moves when u squeeze the trigger. OK..Remember this! Right-Tight...Left Loose. When drill moves to the right...It is tightening (the bit, the screw your driving), left it is Loosening the bit (that falls out) or to take a driven screw out!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Well I couldn't find a pix of your drill so I will guess that it is a typical drill. You seem to be asking a very basic question so I will start will all the basic info I can think of.
First you have to know where the power trigger is to make it go.
2nd you have to know where the forward and reverse switch is.
Now with the switch in the forward position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the center Jaws should close up and come out of the chuck.
Now with the switch in the reverse position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the cetner Jaws should open up and go into the chuck to a maximum point
Open the jaws enough to put the drill in the jaws then put the switch in the forward position. Put the drill in the chuck, sqeeze the trigger to make it go, and hold the chuck so the jaws close on the drill. All while keeping the drill from falling out of the chuck.
When it closes on the drill and the drill is in straight then hold the chuck as tight as you can while squeezing the trigger to make the jaws close very tightly on the drill. If you have very tender hands you might want to use gloves.
To get the drill out put the switch in reverse, hold the chuck very tightly, and squeeze the trigger to open the jaws off of the drill.
