Apple iPhone 3G Logo
Posted on Nov 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My apple iphone USB Device Not Recognize what will
My apple iphone USB Device Not Recognize by my computer what will i do
Anonymous
Level 3:
  • Master 1,188 Answers
  • Posted on Nov 28, 2009
Anonymous
Master
Level 3:
Answers
1188
Questions
0
Helped
350827
Points
3656
Go to www.itunes.com and download and install itunes, then reconnect the phone. If you already have itunes do this, but realize this will clear the info from your iphone, but if you have the info in itunes, it will sync back anyway. So just know, this does a factory reset:
Turn iphone off by holding power button on top left and sliding the red bar to shutdown.
Now, take the usb cable and have it not connected to the computer, but connect it to your iphone, so now you have the usb cable just connected to the iphone which is completely off.
Now, hold down the circle button on the iphone, and keep it held down. Then insert the usb cable into the computer, while still holding the button down. After a minute or two, you will get a screen on the iphone with a white usb wire pictured on the screen, and if you did it right, the connection should then pop up on windows. After you do the restore, you can then use itunes and plug in the usb like normal, all should be fine.
good luck!
My apple ihone is disabled connectto itunes
There are many reasons why iTunes will not recognize your iPhone, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPhone you have, here are a few suggestions for helping the problem of iTunes not recognizing iPhone:
1. Generally speaking, when iTunes does not recognize iPhone, it may have something to do with the version of iTunes. If you are using an old version of iTunes on your computer, it may not be capable of recognizing your iOS devices. So updating iTunes to the latest version is a fastest way to get the problem solved.
2. If you are running iTunes in the latest version, but still can't get your iPhone recognized, you may want to take a look at your computer, sometimes if your computer lacks necessary software, it might lead to the malfunction of iTunes.
3. USB port on your computer can be another reason why iPhone not recognized by iTunes. So you can try more than one USB port to see whether the USB port works well.
4. Of course, your iPhone may also be the cause of iTunes not recognizing iPhone. At this moment, you can restart your iPhone by holding the Sleep/Wake button and Home button at the same time until you see the Apple logo, then connect iPhone to computer with USB cable again.
5. You should also make sure your iPhone trusts your computer, because after changing a new system on computer, your iPhone will regard it as a new computer. What's more, you should check out whether Apple Mobile Device Support is installed on computer.
6. After checking out all the aspects mentioned above, you can try to connect iPhone to computer with the USB cable again.
If none of these methods work out, you may want to try set your iPhone up as new after iTunes not recognizing iPhone. You only need to tap General > Settings > Reset > Erase All Content and Settings, and then choose Set Up as New. When you have set iPhone up as a new device, you are able to connect iPhone to computer with USB cable. But before erasing all contents on your iPhone, you may want to back up iPhone files to computer to keep them safe.
http://www.leawo.org/tutorial/what-to-do-when-itunes-not-recognizing-iphone.html
When i plug my iphone 4s into my pc with itunes running it doesnt recognize the phone, cable is good pc makes sound when i plug in
There are several methods you can try to fix this issue. One of them shows below.
How to Fix iTunes Not Recognizing iPhone in Windows 10 Before You Begin:
  • Make sure that you have the button Trust this computer on your iPhone when connecting to your PC.
  • Make sure that you have installed all Windows updates. This is to make sure that your computer device drivers are up to date.
  • Make sure your iPhone USB cable works well.
  • Make sure your iOS device is turned on.
  • Make sure you have the latest version of iTunes installed.
  • Now, the following solution may help you fix the iTunes issue if you found that your iTunes does not recognize iPhone in Windows 10 computer.
    Step 1. Connect your iPhone to computer and wait for some time until the device is recognised.
    Step 2. Right-click "Computer", Go to "Device Manager". Then expand category "Universal Serial Bus controllers" and locate "Apple Mobile Device USB Driver".
    Step 3. Right-click "Apple Mobile Device USB Driver" and click "Update Driver Software". On the pop-out window, choose "Browse my computer for driver software".
    Step 4. Then choose "Let me pick from a list of device drivers on my computer".
    Step 5. Click "Have Disk..." button.
    Step 6. Click "Browse".
    Step 7. Navigate to "C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers". Then double-click the usbaapl file. If you have a 64-bit version of Windows, this file will be called usbaapl64.
    If you don't see usbaapl64 here or if there isn't a Drivers folder, look in "C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\Drivers".
    Then you need to install the driver for your Windows 10. After installing, unplug your iPhone, then reconnect it using USB cable. Open your iTunes and see if your iPhone can be detected or recognized by iTunes.
    For more details, check: How to Fix iTunes Not Recognizing iPhone in Windows 10
    Iphone is disabled
    If you mean iTunes can't recognize iPhone, follow these steps.
    1. Update iTunes to the latest version. Plug in your iPhone. If iTunes still can't recognize it, then in iTunes in the top left corner click help> run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPhone.
    2. Click on your windows start menu. Type in "services". Click on it and when it pops up, on the bottom of it click on "standard". Now Scroll down to find "Apple Mobile Device" Right click it when you see it and click on "Start". When it has started, close iTunes and replug in your iPod and it should show up.
    3. Check the USB cable
    4. Verify that Apple Mobile Device Support is installed
    5. Restart the Apple Mobile Device Service and verify that the Apple Mobile Device USB Driver is installed.
    6. If you just want to add some photos, songs and movies from computer to your devices, you can use an iTunes alternative to do the job
    http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
    7. Check for third-party software conflicts.
    Ipod disabled
    If your mean iTunes can't recognize your iPod, please follow these steps:
    2. Check the USB cable
    3. Verify that Apple Mobile Device Support is installed
    4. Restart the Apple Mobile Device Service and verify that the Apple Mobile Device USB Driver is installed
    5. You may try this iPod file manager, it's an iTunes alternative that can help you manage iPod files including delete, upload, play, copy, etc.
    6. Check for third-party software conflicts.
    Itunes could not connect to the iphone because an invalid response was received from the device
    There are many reasons why iTunes will not recognize your iPhone or iPad, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPhone or iPad you have, here are a few suggestions for helping the problem of iTunes not recognizing iPhone:
    For more details, check: What to Do When iTunes Not Recognizing iPhone
    How do I pair a RocketScience Tracer bluetooth?
      • 1How to Pair a Bluetooth Device With an iPhone On the iPhone, click on the "Settings" icon. It looks like a gear. Then press on the "General" button. Select "Bluetooth" and then "Turn Bluetooth On." The phone is now ready to be connected to the Bluetooth device.
      • 2 Connect the iPhone Bluetooth travel cable that comes with the iPhone-approved Bluetooth device into the USB 2.0 port on the computer. Do not plug it into the USB port on the keyboard.
      • 3 Connect the iPhone to the other end of the cable. The cable goes into the data connection slot on the bottom of the iPhone. There is another slot on the top of the cable into which the Bluetooth device should be plugged in.
      • 4 Wait while the computer loads to recognize there is something plugged into it. Either a screen will pop up or an icon will appear on the desktop to let you know that the computer is recognizing there is a iPhone plugged into it.
      • 5 Let the Bluetooth device charge with the iPhone for about one hour. You can tell when the device is fully charged by viewing the status light on the device. It will be an amber color until it charges completely. Once the charge completes, it will turn green.
      • 6 Remove the Bluetooth device and the iPhone from the cable that is plugged into the computer's USB port. Push the button on the top of the Bluetooth device. This allows the calls to now go through the Bluetooth device instead of straight to the iPhone.
    My iphone shut down when connect o my computer. i get a error message unknown device not recognize usb
    The possible explanation to this issue would be than the usb port is very old or damaged and it doesnt recognize the ipod usb cable
    you should try to update the usb drivers or buy an new usb interface car if you have a desktop
    Windows 7 no detecta mi Ipod A1236, al ingresar a la busqueda de los dispositivos Windows me muestra el Ipod con un error que dice "Unknown Divice" no funciona correctamente, ya trate de...
    iPhone iPad or iPod not recognized in iTunes for Windows
    Si conecta su dispositivo a su computadora con un cable USB e iTunes no reconoce su iPhone, iPad o iPod, obtenga ayuda.
    Cuando iTunes en su computadora no reconoce su dispositivo conectado, es posible que vea un error desconocido o un error "0xE". Si lo hace, siga estos pasos e intente conectar su dispositivo nuevamente despu?s de cada paso:
    Aseg?rese de tener la ?ltima versi?n de iTunes que funcione con su computadora.
    Compruebe que tiene el ?ltimo software en su Mac o PC con Windows.
    Aseg?rese de que su dispositivo est? encendido.
    Si ve una alerta de Confianza en esta computadora, desbloquee su dispositivo y toque Confiar.
    Desconecte todos los accesorios USB de su computadora, excepto su dispositivo. Pruebe cada puerto USB para ver si funciona. Luego prueba con un cable USB Apple diferente.
    Reinicie su computadora y iPhone, iPad o iPod.
    Intente conectar su dispositivo a otra computadora. Si tiene el mismo problema en otra computadora, comun?quese con el Soporte de Apple.
    If you connect your device to your computer with a USB cable and iTunes doesn't recognize your iPhone, iPad, or iPod, get help. When iTunes on your computer doesn't recognize your connected device, you might see an unknown error or an "0xE" error. If you do, follow these steps and try to connect your device again after each step:
    1. Make sure that you have the latest version of iTunes that works with your computer.
    2. Check that you have the latest software on your Mac or Windows PC.
    3. Make sure that your device is turned on.
    4. If you see a Trust this Computer alert, unlock your device and tap Trust.
    5. Unplug all USB accessories from your computer except for your device. Try each USB port to see if one works. Then try a different Apple USB cable.
    6. Restart your computer and iPhone, iPad, or iPod.
    7. Try connecting your device to another computer. If you have the same issue on another computer, contact Apple Support.
    4answers
    ITUNES DOES NOT SEE MY IPHONE
    the same exact thing happen to me......then I purchased a new connector (I used the old usb so much with the ipod)...and bingo itunes recognized the iphone......
    Says connect to itunes but i cant because im in another state
    It's a common issue. You can check below steps to fix it.
    How to Make iTunes Recognize iPhone There are many reasons why iTunes will not recognize your iPhone or iPad, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPhone or iPad you have, here are a few suggestions for helping the problem of iTunes not recognizing iPhone:
    For more details,check: What to Do When iTunes Not Recognizing iPhone
    Top Apple Cell Phones Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ADMIN Andrew
    ADMIN Andrew
    Paul Bade
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
