Here are the codes for the Sylvania TV/DVD combo from the RC64 manual.
20675, 21268
If you have more questions I have the manual in hand. Please ask. I will be back in 15 mins. If you need to know how to program it just ask me.
Good Luck
too work the combo unit you have to put the switch in the AV1 or the AV2 position to work your TV/DVD. Do you have the manual.
You can also try these codes in the TV position. It will only work the TV though not DVD.
10054, 10030, 10171, 10020, 10028, 10065, 10096, 10381, 11271, 11314, 11394, 11931, 11944, 11963
If you need manual I have one online I can send you.
Have you done the code search to see if your TV/DVD is supported by the remote.
Then the remote will not work with the TV/DVD. If you would like you can call Direct tv at 1-800 directtv they will be able to help you out more.
You can program the Direct TV remote to control your TV by using the below steps:
1. Turn on the TV
2. Slide the MODE switch to the TV position.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
4. Using the number keys enter the 5-digit code (20675, 21268). If performed correctly, the green light under TV flashed twice.
5.Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying the other code.
6. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
For further details and programming procedures and codes, you can download the complete user manual for your remote by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks for using FixYa.
Thanks for the feedback.
If you have already tried the codes and programming procedures in all the three positions, i.e; TV, AV1 and AV2 and still it does not work, you have to manually search for the correct codes or try the other codes for Sylvania TVs:
Hope this helps. Thanks once again.
Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code in the following boxes
OK.
Evidently you have never tried programming this remote. If the mode switch is in the TV position it will only allow codes starting with the numeral 1 (one). 10000-19999. I have read the manual several times and have tried the two codes that you suggested, but the mode switch has to be on AV1 or AV2. It still doesn't work. I cannot accept this un-doable solution and have probably wasted $12.95 inless you have a workable solution
I have the Direct TV reciever remote RC64 that I would like to work with my new Sylvania LD320SSX Tv/DVD Combo. I have tried all the codes that was listed for Sylvania and Funai (the manufacturer) but I cannot get the remote to control the volume or power. Please do not tell me something that's in the manual, I have read it several times.
Like I told the previous EXPERT with the mode switch on the TV position the remote will only let you enter codes that begin with the numeral 1 (one). Only numbers between 10000-19999 can be entered. I have also tried the mode switch in AV! (it will take those numbers) but it will not control the TV function i.e. volume, power, etc. Also I spent 45 minutes using the searching for codes, so please do not suggest that next.
I have the manual, which I have read several times. If the solution was in the manual I would not have paid $12.95 to get an answer.
I have spent 40 minutes with the mode switch on TV and about 30 minutes with position AV1.
