Blue polarizing filter is burned or blue lcd panel is faulty.
Unfortunately I saw the same problem, I disassembled the projector and found the burned LCD.
I found the parts number is:
A-1484-251-A PRISM BLOCK ASSY
no single panel, only assembly is available.
I'm getting estimates, I hope it does not cost much...
SOURCE: Hitachi projector model CP X260 projects yellow spot on screen
blue blotches on screen due to dust get optics cleaned should then work ok...yellow spot more likely to be lcd or lens burn a much more serious and expensive problem
SOURCE: InFocus LP 850 Projector, yellow spot on screen
Unfortunately the discoloration is caused by the extreme heat generated by the Lamp has burned the LCD optical polarization filter/elements.
The only solution for this is to replace the entire LCD optical assembly.
Sorry for the bad news, :(
