Kitchen Ranges Logo
Posted on May 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove melted plastic from a gas range?
I've got a black Kenmore gas range and recently had part of a teakettle cap melt on the painted surface of it. I was able to scrape some of it off with a plastic scraper, but I'm afraid to do anything more in fear I might scratch the surface. I also turned on the burner for a bit in hopes that the plastic would soften enough for me to scrape it off, but that didn't work either. The part that is melted looks like large droplets of black water and it is extremely hard. Help?! (keep in mind, this is not a glass cooktop, but a black painted gas range)
Kathryn Lano
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 03, 2017
Kathryn Lano
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
268
Points
Place several paper towles (damp or dry) over the melted on plastic and then use a hot iron (I used cotton setting with steam) on paper towles as it remelts plastic, paper towles lifts it from the top stove surface. It can take several go overs using new paper towles time. My niece left her doll too close to my stove and her dolly's hand and arm melted to my stove top, and this did the trick.
Norma Garcia
Level 2:
New Friend:
  • Expert 44 Answers
Norma Garcia
Expert
Level 2:
New Friend:
Answers
44
Questions
Helped
24538
Points
122
Try melting it with a propane torch heating the plastic only then when it's good and melted wipe it with a cloth be careful not to burn yourself wear leather industrial gloves melted plastic gets lava hot and will leave a nasty burn repeat the process until all plastic is gone
Nigon Kouk
Level 2:
An expert that gotĀ 10 achievements.
New Friend:
  • Expert 41 Answers
Nigon Kouk
Expert
Level 2:
New Friend:
Answers
41
Questions
0
Helped
13539
Points
115
5 Related Answers
Anonymous
  • 29 Answers
  • Posted on Jan 29, 2009
SOURCE: My Kenmore glass top range,
SOUNDS LIKE YOU MAY HAVE A WIRE BURNED. CAN YOU USE A MUTIMETER?
Anonymous
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
dealt_soul
James Bradburn
  • 299 Answers
  • Posted on Feb 15, 2009
SOURCE: Plastic melted on burner- how to remove?
If you can break away the plastic then you will be fine, but never use a scraper on them. If all fails replace.
Anonymous
  • 107 Answers
  • Posted on Apr 09, 2009
SOURCE: Glass cooktop scratched
Unfortunately, these style cooktops are VERY fragile to scratching and cracking. The wrong kind of cookware can also mark them. Copper or aluminum pots and pans can discolor them. Do not use pyrex (glass) cookware on them either. Stainless is the best. NO CAST IRON either. Anyways, there's not much can be done without replacing the top itself.
Paul Carew
  • 3807 Answers
  • Posted on Jan 18, 2010
SOURCE: melted plastic on tempered glass on a gas fireplace
try using a ceramic hob cleaner to get it off
Kenmore dryer
found this..
Step 1 Run the dryer on a regular setting for 20 minutes to soften the plastic. Scrape the plastic off with a wooden or plastic spatula or paint scraper, taking care not to damage the dryer's interior.
Step 2 Apply 1 to 2 tsp. nail polish remover to a clean cloth, and rub the plastic to dissolve it. Rub the area with a damp cloth to rinse the nail polish remover.
Step 3 impt! Mix 1 tsp. liquid laundry soap with 1 cup water. Dip a clean cloth in this solution, and rub the area again. Rinse well with a cloth dipped in clean water.
Where do I find high temp paint to use on a gas stove?
Auto parts stores have manifold and engine paints for high temp use, or the hardware store has barbecue and wood stove paints, usually black. Your stove may have been enameled (Melted glass powder process, like ovens, old sinks and bathtubs).
8helpful
3answers
Burner knobs melt on GE Profile XL44 gas range.
I had the same problem and searched extensively for a solution. They even have a video from GE on the net telling you how to avoid melting them, which is basically don't open to broil and make sure the seal is good on the oven. Essentially, don't use their oven normally like the rest of the ovens in the world. Finally I went to a few show rooms to look for a knob to substitute for the garbage ones from GE. On one of the new models they have a solid cast stainless knob (with a plastic shaft, I think it is delrin) which looks identical but has a longer shaft. I obtained the PN which is WB03T10262 and ordered one. I trimmed the shaft length to match the length of the defective knob with a hack saw, and had to trim out some mold flashing in the cavity. After a couple of fittings I was finshed and it looks fine. I then ordered 3 more from the Appliance Zone for $15.98 each. GE's price for the same part was $25.25!!
Cleaning melted plastic from oven
i found this on the internet..
For a regular electric oven: Place a bag of ice directly on the melted plastic to chill it and make it more brittle. Then carefully, using a razor-blade scraper, lift off the puddle ofplastic. This procedure will not hurt an interior porcelain finish. For a regular gas oven: First turn off the gas..
plus you could go to this link if you need more help..
Cleaning melted plastic from oven Google Search
Tin foil melted in my oven.
hi floppy,
if you can't scrape most of it off with a plastic scraper, you may have to buy a new bottom pan. if you can get most of it off it should be ok to use. also if you have propane gas make sure your stove was converted properly.
Melted plastic *bread wrapper*
mix vinegar and water in a container,turn the element on to the highest setting.get a METAL paint scraper pour the solution onto the element while scraping off the plastic.hope this helps.
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
