These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Your unit has DC Offset(a damaged amplifier) which is why it keeps shutting down. If you are interested in repairing your Sony, please visit my website at audioserviceclinic.com. Thank you.
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
When it shuts down, do the LEDS on the front blink? There are 3 of them. Standby, temp and lamp. Do any combination of the 3 blink when shuting down. I could tell you where to start just by those lights blinking.
Normally when this happens it is because the impedence load is too small. This unit requires 8 Ohm speakers. If you connect 4 Ohm speakers, it will work, but work harder and generate excessive heat. If the heat is too much, the unit will enter protect mode and shut down. Once it cools off, it will work again. In your case, if the speakers are the correct impedence, check for crossed wires. If that is the problem, running the unit at higher volume levels should cause it to shutdown sooner.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
