Could be a couple of things. Transformer can be bad. Try connecting the two wires (usually wired red and white) from the transformer to terminal W and C on the circut board. Your bypassing the transformer and if installed a current sensing relay. The furnace transformer will/should handle the extra load. Turn on the furnace, if still not working, loosen the water supply line at the water solenoid on the humidifier, if water flows out then your supply valve isn't clogged, if no water then try screwing in the needle on the supply valve all the way in then back out. If still no water then the valve is clogged. If all is good then it looks like the water solenoid is bad or wiring to valve/humidifier control. Don't find the controls bad that often. Have fun!
Make sure Humidistat is set before doing anything else.
