HP Compaq 6735s battery light is blinking orange, with any combination of power cord and/or battery connected, EVEN WHEN THE BATTERY IS DISCONNECTED!
Hp 6735s when power on not display
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Testimonial: "awesome, thanks, i'll try that :)"
Iv found that if i start the laplop with the batt + ac both connected then after 2 or 3 secs unplug the ac for a sec or 2 then plug it back in it works!!!! i hope this helps lots of ppl
If you need a new discount HP Compaq Business Notebook 6735s battery, Li-ion 4400mAh 10.8V with one year warranty and 30 days money back!
You can buy one HP Compaq 6735s battery in
UK: http://www.hp-laptop-batteries.co.uk/hp-compaq-business-notebook-6735s-battery.htm
http://www.all-batteries.co.uk/notebook-batteries/hp-compaq-business-notebook-6735s.htm
USA: http://www.notebook-battery.org/notebook-batteries/hp-compaq-business-notebook-6735s.htm
Australia: http://www.aubatteries.com.au/laptop-batteries/hp-compaq-business-notebook-6735s.htm
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the back up( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. If not the OS is a suspect.
It is also possible that the mother board is faulty but can be confirmed only after you ensure that the memory and power supply is good.
Thank You for using Fixya
even with NO BATTERY it does this
sound like a dead battery.
