Panasonic Technics Multi Compact Disc Player 5 cd changer Model SL PC11 will pick up cd but not play. I used an optic cleanser, but the changer continues doing the same thing in the remaining 4 cd spaces.
Re: Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
System will not play Mp3 or data format cds. Audio cds only . Also Clean lenses with a cd lenses cleaner . clean cd also straight away from center ,soft cloth Check for scratches .
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
