1.Power cable to CPU.
This you have to attach this with CPU in necessary to three pin.
2.Power cable of CPU to switch board
If you have not plugged your cable to switch board then it could not work in proper,if your wire is too short then connect it with some appliances like two modular or some power suppliers to connect your power to the main board.
3.If you talking about the switch of CPU for starting it.
Connect the bolts together with the help of some holder connect it.
If you look closely on *********** board, you will see the PW SW printer on the board.
This is the on off connection to be made by the power switch.
See the diagram of front panel
Please include the motherboard model number and manufacture's name. Not every MB power switch connects the same. See pic's below; Mike
