Veo Observer Network Camera Logo
Posted on Jan 14, 2008
Veo wired web cam
I have veo webcam that i have not used in sometime, i need the dafault user abd password to log onto it. Can you help with this
evlecho
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 11, 2008
evlecho
Contributor
Level 1:
Answers
Questions
0
Helped
534
Points
Username : admin
password : password
to reset it to factory default, press power button for 6secs, and you should see the number chagne to 300, then you can release the power button, the observer should turn off, when you turn it on again, it should now be back to the factory default settings
I'M NOT ABLE TO USE MY WEB CAM IN SKYPE PROGRAM MY WEBCAM IS VEO 650VS26X
You can try this ........ www.manycam.com
download manycam v 2.4.44
install the software first
then plug in veo web cam and it should work
NEED MY STINGRAY WEB CAM REINSTALLED INTO MY PC
First write down the model and serial number of the web cam. After that is done completely disconnect it from your pc and log onto the net. Go onto the web cam makers website like ummm "doodle cam" and find the MAIN site for the company. There is a place that will say "downloads" search for the download of your DRIVER for your particular moddle number and download the correct driver. After your done just follow the steps provided. Most companies do this because the yrecognise the fact that customers loose things such as install disks.
Free veo web cam driver
1st You download Webcam Driver. Free Veo Webcam Driver After this install the webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Cannot use web cam
this link will certainly help
http://tech.nztechie.com/2008/01/install-veo-advanced-webcam-on-windows.html
if it does please do rate the solution if any other assistance is requires please do post.
1helpful
2answers
VeoNetwork Web cam
You can view your Veo Observer web cam at home by either of two methods. The first is to use the Observer Studio software that came with the camera. When you configured the camera, you selected a local (private) IP address for each Veo Observer, and set the address specific to each camera. You then put the same IP address into your Observer Studio Software.
Depending on the brand of router you use on your home network, your Veo Observer camera probably has a local (private) IP address in the format 192.168.0.xxx or 192.168.1.xxx where "xxx" is the actual address assigned to your Veo Observer (by you) and configured to display on the LCD window on the side of the Veo Observer.
You may need to log into your router to see which of the two local (private) IP address formats is used. Your router's user manual will show you how.
To view your Veo Observer, just type the exact local (private) IP address in your IE browser. for example, if you assigned address 100 to your cam, you would enter http://192.168.0.100 or 192.168.1.100 into your browser. Veo Observer will display the Language selection screen. Choose the language, then you log in and view your camera.
To view your camera from outside your home using another computer, you use the same method, but you have to substitute your WAN (public) IP address.
You can log into your router and select its STATUS tab to view your WAN (public) IP address. See you router's set up guide if you do not know how to do this.
An easier way to determine your WAN (public) IP address is to visit Gibson Research Shields Up! web page:
https://www.grc.com/x/ne.dll?bh0bkyd2
and scroll down to the last paragraph where you will find your WAN (public) IP address.
For example, if this address is 123.456.789.100, then you would enter http://123.456.789.100 on your IE browser. You should see the Language select screen, choose your language, then log in and you are now viewing your Veo Observer from outside your home.
Note: when you view your Veo Observer at home, you probably have a fast frame rate and smooth video motion. When you view your Veo Observer from outside the home, the frame rate is certain to be less, and your moving image quality will be choppy. This is normal, as viewing from outside the home is less efficient and the image suffers. There is nothing you can do to boost the frame rate.
8answers
3answers
Finding Software dwnloads for Veo Stingray Web Cam
hi there
you can download your webcam software here...
http://www.veo.com/Stingray/drivers.asp
includedin this page is your software for veo.
hhope this helps
2answers
Does veo have a driver for vista?
http://www.softsci.com/veodrivers.htm is where you can download the drivers
Top Veo Computers & Internet Experts
ExpressFiX
ExpressFiX
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
