Hello.
Here are some suggestions from Lexmark as to why the printer will not duplex:
The ability to select duplex printing requires the following:
Printer recognition
of duplex option
Some printers and MFPs have the duplex
option built into the physical printer while others require physical connection
of the duplex option or tray.
-Transparency
-Labels, or
-Cardstock/Extra Heavy Paper.
-Booklet printing
-Poster
printing
To check for an installed duplex
option:
Print a Menu Settings page and check for DUPLEX
under Device Information > Installed
Features. (The embedded web server path is Reports > Device
Settings > Device Information > Installed
Features.)
If DUPLEX does not appear as an
installed option, consider the following possible reasons:
-The duplex drawer or tray is not
properly connected to the printer. Try reseating the printer onto the duplex
option so that the duplex option's upper auto-connect connector is properly
aligned with the printer's bottom auto-connect connector. NOTE: A "982 duplex
error" may also result from this condition.
-Turn the printer off for about 15
seconds, and then turn the printer back on. If the printer was quickly turned
off and on, a low-voltage power condition could prevent the peripheral
from being acknowledged during the initial printer start-up.
-The auto-connect connector is damaged
on the printer or duplex option.
Software
driver recognition of duplex option - reinstall driver.
Hope these suggestions help.
