GE Spectra Range
Model: JB960C084CC
Problem:
Oven achieves the set temperature.
The oven cools without maintaining the set temperature
AND the digital display keeps showing the set temperature.
Example:
•Set oven to 375 degrees.
•Display begins at 100 and increments until 375 is achieved.
•Wait 15 minutes
•Turn OFF oven.
•Reset oven to 375 degrees.
•Display begins at 352 and increments until 375 is achieved.
Thanksgiving Day is a BAD time for this to happen.
We had to keep resetting the oven every 15 minutes and dinner was delayed over an hour.
Any suggestions?
SOURCE: GE Spectra XL Oven does not maintain oven temperature
The most logical solution for your problem would be a faulty thermostat, but yet at the same time i dont understand how it would heat to the temp desired then not come on at all. I would definately change the thermostat to start off with. Let us know :-D
SOURCE: GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp
probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to
control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
SOURCE: GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
SOURCE: About six months ago, my GE XL44 gas range
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
