Open device manager. (Settings, Control Panel, System)
Expand system devices.
Open PCI Bus, then IRQ steering.
This should generally be enabled, but disable it if it isn't working for you.
When you restart the computer check the system bios (Usually "Press <del> to enter settings" to see whether you are allowing the operating system to control devices through Plug and Play. Either setting may work, but setting to Plug and Play Operating system is generally better with IRQ steering enabled. Try all combinations.
Although MS no longer supports Win98 you may find that Windows Updates still works. You should take whatever updates are available.
Usb
