Our side by side refrigerator is not cooling. The freezer is cold (zero F), but the refrigerator is at 58 degrees F. Model no MZD2766GEB
The coil freezes up solid. i take the inner liner out and take a heat gun to the coil, speed defrost and reassemble. 6 screws max.
Maybe the fan here is a site where you can go and look at it it's part number 15 the nut may have come loose.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47964&diagram_id=685481#d685481
I hope there is a good solution to this one because I have the same problem. Must be a common issue with this model. Nothing but trouble.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Refrigerator or Freezer not Cooling or Getting Cold ////////////////
heatman101
heatman101
