2001 Dodge Grand Caravan Logo
Posted on Nov 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 Dodge Grand Caravan. Dash board stopped
2001 Dodge Grand Caravan. Dash board stopped working, still lights up, but no readings. When I put my foor on brake everything on dash lights up. Signals do not work (only the front with my foot on the brake??
Johnny Brown
Level 3:
  • Dodge Master 5,763 Answers
  • Posted on Nov 26, 2009
Johnny    Brown
Dodge Master
Level 3:
Answers
5763
Questions
0
Helped
3163946
Points
20432
Sounds like an electrical nightmare! start by removing the cluster,now try signals are they working if yes then bad cluster, also i had a few caravans that just had bad connections i removed the plugs and reconnected them and it worked fine, also with the light coming on with your foot on the brake may be a bad or in correctly installed bulb, check all brakeand signal bulbs, try all of this , good luck,hope this is helpful.
All instruments on dash board are out after replacing alternator
Check fuse for dash lights...Anything else not working???
I need to know how to access light bulbs in the center panel where the heater controls are. Initially only one control backlight was out. Now light behind the rear control switch is out. Thanks
Dodge Caravan (01-03) Instrument Panel light replacement ...
? 12:25
https://www.youtube.com/watch?v=d9qi78IAPF0
Mar 4, 2013 - Uploaded by ryanthiusjunk
A common issue with the Dodge Caravan (and Chrysler Town ... I just bought a Dodge Grand Caravan (2002) and noticed that the entire dash board didn't light up at night. Needless to say I needto replace all of those bulbs and after ... do you know how to fix the 2009 caravan instrument panel lights going ...
DIY Dashboard Light Bulb Replacement - YouTube
? 8:07
https://www.youtube.com/watch?v=_bf5w3AZR_0
Jan 7, 2013 - Uploaded by Chris Punt
How to replace dashboard lights on a Dodge grand Caravan. ...Most just want to get the bad bulb out and put new one in. it seems to me the ... pull the dash panel out far enough to turn it upside down on the column and ... Bought mine at Advance Auto, but I know it is not a hard bulb to find and can be ...
2001-2007 Dodge Grand Caravan/Chrysler Town and ...
I cannot find the fuse for cigarette lighter on my 2001 dodge grand caravan sport
Open the drivers door. pop out the panel on the end of the dash.
2009 dodge grand caravan error message on dash board no bus or no bu5
the info bus is down try unpluggin the crank sensor on the right side of the transmission see if no bus goes away al see computer cause this issue
My dash has quit working on my 2001 dodge caravan
Have you ever had any work done in that area? Check all fuses and the back side of the fuse cover points you to what each fuse does. If you've had damage to the dash it is quite likely where your problem is.
ABS light turns on a 1998 dodge grand caravan and the guages stop working
You definately sound as though you have an electrical short. I would have a mechanic do an electrical test.
My 2001 dodge grancaravan lights on the dash stay on
Not sure this helps but sometimes this is caused by a bad igntion switch. you can try to wiggle it with out shutting off the van,
1helpful
ABS and break lights on dash board light up at around 20km/h and stay on. Dodge grand caravan 2001
Something is wrong with the ABS system. After the ABS system runs through it's self check when you get moving, it find a fault in the system. Do you have a code??? Go to any good auto parts store that will come out a check the codes for FREE. Call them first.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
