Numark DJ/iO Sound Card Logo
Posted on Nov 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The sound keeps on clipping (stopping and starting) - this is on my new dell pc which has windows 64 bit installed. i previously used dj io perfectly on my laptop with 32 bit vista installed - anybody know what can be done?
Anonymous
Level 3:
Guru:
  • Master 1,738 Answers
  • Posted on Nov 26, 2009
Anonymous
Master
Level 3:
Guru:
Answers
1738
Questions
Helped
470535
Points
4963
It is not design for windows 64 bit, If it works perfectly on windows 32 bit, then it is windows 64 bit.
  • kuhnertm23 May 09, 2011
    I am having the same issue with my Macbook pro, which just start a few weeks ago. Do I also need an update?
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
I am running Windows 8.1 on an Inspiron 15 64-bit machine. I need software for my Dell Pocket DJ 5GB. When I connct th DJ to the PC there's a tone as fo the PC recognizes the device. However, the device...
I think your Dell pocket DJ is an XP based Operating system.
1 press the start button
2. go to all progams and choose windows update and update your laptop
3. when the update is done, restart your system and try again.
Please tell me the pocket version you are using?
I have windows 7 and it is a 64 bit operating system, when i plug the dj io into my usb connection and try to install the drivers it comes up as not recognising the hardware and keeps saying that the...
Good day,
Is your Numark DJ/io soundcard comes with a software cd/dvd. You need to install it first in your system to use it. If you have no cd. Try downloading on the product website for the software. Tnx
Make sure you got software with this program that is 64 bit compatible,i heard Numark just released 64 bit support for DJ/IO and your card supports multiple outputs
1helpful
When installing numark dj io during installation it always says unfortunately the installation failed. (Error: Timeout - 0x0005)
check all usb connections, with any other device like pen drive, if pen drive is working perfectly , then go to " control panal" go to "add or remove programme " and uninstall any " ASIO drivers or softwares" . and restart the PC and install the device and software, drivers as told in the product manual.
if still have problem - change the RAM of your PC,
best of luck and KEEP SMILING .aaarwind
MyDJ IO sound card keeps making a horrible ringing sound
you may need to update the drivers for your device
also check the supplier feed back or reveiws on this model to help troubleshooting for the future
2helpful
2answers
I would like to buy a new dell but not sure how much memory i would need. I don't recall how much memory is in my previous dell. It is a dell dimension xp. Would you please let me know how many GB there...
With any new computer you should get 4 GB of memory, the more the better. There are two version of Windows you can get 32 or 64 bit. The 32 bit version of Windows has a 4 GB maximum on the memory, the 64 bit versions go much higher depending on the version you get. 4 GB will give most people more than enough to do what they need. To see how much memory you currently have just Right-Click on the My Computer icon and select properties. In the window that comes up you will see the memory you currently have.
2answers
Virtual vinyl 6 64 bit driver
i have virtual vinyl and have the interface box , it will not read on a 64 bit laptop on windows 7 , do i need to buy the dj /io box for it to work ?
1helpful
How to sync Palm T3 to (Dell) 64 bit laptop via Bluetooth
if you are using 64 Bit operating system you may use following procedure
1) Start > Run > msiexec /unregister
2) In regedit, find the following key:
HKEY_LOCAL_MACHINE\
SOFTWARE\Microsoft\Windows\CurrentVersion\Installer
3) Change MsiExecCA64
From this: C:\WINDOWS\system32\msiexec.exe
To this: C:\WINDOWS\SysWOW64\msiexec.exe
(This assumes a default Windows directory.
Change to reflect your configuration if needed.)
4) Restart the Windows Installer service
(Control Panel > Administrative Tools > Services)
5) Install Palm Desktop!
To go back to the previous settings, just reverse the change made in the registry, and stop/start the service again.
You can also set it back to normal by re-registering the installer:
Start > Run > msiexec /register
Top Numark Computers & Internet Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
goneforever.
Are you a Numark Computer and Internet Expert? Answer questions, earn points and help others
