Bose Acoustimass 10 Series IV Home Entertainment Speaker System - White Logo
Posted on Nov 26, 2009
Need a Music Center for my Bose Lifestyle 8 System. Where can I buy one?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
186
Points
I have one, in good order $300.00
Blown power supply, what does it look like?
There's a power supply in the sub-woofer (acoustimass) module and an adapter module for the music center.
There are several different power adapters for the music center, and the different types are all depicted in the users manual here:
http://www.bose.co.uk/GB/en/images/Lifestyle%2030%20Series%20I%20Home%20Theater%20System_tcm6-4078.pdf
Hope that helps!
I'm missing the audio input cable for my Lifestyle 20 music center. Where can I buy one?
i"m missing the audio input cable for my lifestyle 20 musc center please tell me where can i buy it
My base module doesn't work anymore , can i replace it with another brand or amplifier
There's a base unit on eBay for bid, currently around $90, expiring tonight at 15:45 PST
http://cgi.ebay.com/Bose-Lifestyle-12-control-system-new-box-w-o-cord-/170595656943?pt=LH_DefaultDomain_0&hash=item27b84b24ef
another $210 Buy-It-Now
http://cgi.ebay.com/BOSE-LIFESTYLE-5-8-12-EXCELLENT-EXTRAS-AND-REMOTE-/260731188231?pt=LH_DefaultDomain_0&hash=item3cb4ca3407
$204 BIN...
http://cgi.ebay.com/Bose-Lifestyle-5-8-12-Music-Center-Near-Mint-/180620466103?pt=Receivers_Tuners&hash=item2a0dd197b7
Bose products are highly proprietary. If they have non-standard connectors from the amp or in the speakers I'd take that as a clue they're NOT compatible with other manufacturers' products.
2answers
Bose lifestyle 48 won't play stored music. Everything else works fine
Hard drive is ****..... impact computers.com hard drive number is MK4026GAX pull out of system and replace look at my other posting for 801 code!!! and dont be a ******** again and buy a bose!! TELL YOUR FRIENDS , FRIENDS DONT LET FRIENDS BUY BOSE!!!!
1helpful
Need a power cord for a Bose Lifestyle Model 5 Music Center. Seriel #U288342.
that is a ac adaptor for the ls5 think it's a 12ac not dc output ,be careful. get one from bose.
No sound from centre speaker on my Bose Lifestyle 8 series 2 system. I've checked leads and speakers by swapping them around. If it is the Acoustimass module which units are compatible?
Check your audio settings, via the on-screen menu. The center channel may be turned down. When set at -5 to -8, the center channel speaker may be practically inaudible. If raising the volume of the center channel does not solve the problem, then you do have a dead center channel. The system would then be in need of repair.
18helpful
No LED Display On The Bose Lifestyle Model 5 Music Center
Hi, you have to replace the 100uf capacitors c14 c15 c16 c17 and c19 on the digital board, that will cure your LED fad problem.
Chris.
2helpful
Bose lifestyle fault code 802
Here's what the Bose support website suggests.  Good Luck!
Messages displayed during a Music Information Update
Messages may appear on your media center display during a Music Information Update. If you see a message with instructions to call Bose, and a three-digit code such as "Error Code 802" or "Failed 172" while performing a Music Information Update, it does not necessarily mean there's something wrong with the system. Performing a media center reset and installing the update again may address the issue.
To reset your media center, follow these steps:
  1. Turn the media center off. Wait two minutes
  2. Unplug the power cord from the media center. Wait 30 seconds
  3. Reconnect the power cord
  4. Wait until "Bose Lifestyle" disappears from the screen
Note: After a reset, you will need to wait several minutes before playing stored music (3 to 20 minutes, depending on how many CDs have been stored). All other sources will be available immediately after the system powers up.
If you have any additional questions about these messages, please contactBose® Technical Support or call 1-800-278-1281.
5helpful
2answers
Bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
