I have a Sony
KDL46XBR4 LCD . It is dark on 2/3
of the screen from the middle to the right side that does not seem to be going away and I'm experiencing ghosting when there is any fast motion on the right side as well. I'm hoping its the right inverter board not the LCD itself.
Thanks
ITS THE PANEL ASSY. I JUST HAD MY REPOACED. SONY WILL HONOR A COURTSEY WARRANTY UNTIL 2012
Easy $5 Fix with baby steps: Bad 25v 3300 capacitor on main back video connection board. Take the back off. Stand Tv up. Connect a video signal(dvd etc). Turn on tv to that input. Locate cap(brown on this Tv) behind right steel support bar. Heat up cap with blow dryer. Watch picture correct(not gradually, it will just pop in) itself. Now shut it down, unplug it, let it cool a bit. From the bottom, remove the #3 & 4 screws from right steel support bar. Just slightly tilt top of tv to release top of steel bar. Now you can pull it toward you and wiggle it off the bottom. The board the cap is on is a bit hard to remove.
Quick and easy cap removal: Note that the right side is negative and its printed on the board. Grab the cap with pliers and pull it out. Clean and trim the leads to 3/8 inch that are still attached to board. Trim new cap leads. Solder cap to leads. Bend cap side ways to clear steel support if necessary. Turn on Tv and find a beautiful picture. Now put it back together. You're done.
I am having the same problem. can someone please guide me how to carry out the above fix? I am not sure which cables he wants soldered
