Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Nov 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water will not shut off on its own even after the entire wassh cycle is done
Anonymous
Level 2:
  • Expert 255 Answers
  • Posted on Nov 25, 2009
Anonymous
Expert
Level 2:
Answers
255
Questions
0
Helped
129335
Points
807
There is a water pressure sensor that can tell how full the washer is. This is probably the culprit, as the water is now just cascading into the exhaust system. What causes the thing to stay on is a collapsed microswitch in the sensor biscuit, or the tube leading to it is clogged. Have this level switch looked at.
  • Anonymous Nov 26, 2009
    I made a mistake and need to add: When a washer does not stop filling, it is most likely the water lever biscuit diaphram is ruptured, or the tube that leads to it is leaking or has been pulled off. Still have the level switch looked at. One curious thing, however, the level switch is supposed to disable any motors until the unit reaches the proper level. If you have an electronic timer, your described symptoms might be able to happen but is unlikely, but with a mechanical timer, I cannot think of how this might happen at all. Therefore, the probable culprit is the electro-mechanical water valves that the hoses hook up to on the rear of the machine. Have those looked at. Thanks for being patient.
2answers
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Hi-i have an lg wasshing machine 5.5kg wf-t552c.wont spin outside drum-lower plastic disc in drum spins only-drains water ok.
Now you meant that the agitator shaft works but the drum does not work. So the fault seems associated with the motor drive and could be a belt failure or a drive failure.
In this case it is important that an observsation into the fault from the motor drive is important to confirm the cause as it seems mechanically related.- since all other functions works according to the cycle.
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
The water runs during the spin cycle. The clothes
Does the water run through the ENTIRE spin cycle? There is a period where the water will run during the spin; This is called, the "Final Rinse". But it usually only runs for about 10 seconds then stops.
1helpful
Cold water does not shut off during the entire cycle . Model # 110.26912690.
Hi, If the water continues to fill even when the washer is turned off, you will need to change the inlet valve. If the water turns off when the washer is off, you will need to check the water level switch.
Please let me knwo what it is doing exactly so I can assist you further.
Vic
Suds, then f35 code
sounds like ur suds sensor, u may be using wrong detergent or to much detergent should be using H.E brand, you may be able to run several wassh cycles with only water and a little vinager solution to clean it out?
1helpful
Cold water continues to run during entire wash cycle
Adrea, sounds like you need a new valve. When it's doing this leaking, unplug the washer. If it's still leaking you know for sure it's the valve. Part number for the model posted is 22002360. Catriver..post back.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
