ABOUT HALF THE TIME, THE PRINTER DOESN'T GRAB PAPER TO PRINT, OR IT GRABS IT HALF-WAY. ONE THING IT MIGHT BE IS A LITTLE THING IN THE PAPER TRAY THAT HOLDS THE PAPER TIOGHT - PART OF IT BROKE OFF, SO THAT IT'S NOT SNUG IN THE TRAY. DO YOU SELL THAT LITTLE PLASTIC PART??
THANKS,
R GEISLER
SOURCE: Paper not grabbing
There are two possible solutions for this problem.
Usually it is due to the pickup roller wearing or becoming contaminated with toner or paper dust.
Simple solution, clean the pickup roller, the best thing for this is WD40, put a very small amount on a clean cloth and wipe the roller underneath the printer. Use a clean dry piece of cloth to wipe off any residue.
More complicated solution, remove the roller and reposition, you will need two small flat-bladed screwdrivers to pry apart the retaining clips, remove the roller, a tight squeeze beneath the laser housing, reposition and clean as above then refit the roller. You should find that the paper is picked up cleanly once again.
I hope this helps,
SOURCE: Printer will not grab paper
Check to make sure the paper sensor tab moves freely. You might try air dusting around the paper pick-up rollers to make sure the area is free from any accumulation of dust, dirt, or paper residue.
SOURCE: I have a m3027 mfp hp printer top feed won't grab
turn the power off.remove ink cartridge then check there is not any paper jam.aslo check in back side of printer for paper jam .also clean your ink cartridge try other ink cartridge.
SOURCE: My MP460 printer wont grab paper and feed through
It sounds like the pickup rollers are worn or damaged and would need to be replaced
