Here's what you need to do to fix it: Find some way to get Partition Table Doctor (http://www.ptdd.com/download.htm) and put it on either a live boot CD or from a secondary hard drive installation. Once you have that, Scan the partition for errors and select fix boot... Then if you're running Vista get a copy of Vista Recovery Disc (
http://blogs.techrepublic.com.com/window... burn yourself a copy of the disc, and run it at the boot of your computer. Once the cd is loaded, click on REPAIR WINDOWS, select COMMAND PROMPT, then use this command: bootrec.exe /fixboot
If that doesn't work use: bootrec.exe /rebuildbcd
and see if your windows boots.
IF you have windows XP, boot up with the Windows XP cd, select Repair (R), go into the command prompt (selecting which windows installation you want to modify) and then type this command: fixboot c:
See if your computer boots now.... The important thing is to try to repair your boot which has been deleted or corrupted, that is why it gives the error: err2err3
Try different recovery tools like Table Doctor
http://www.ptdd.com/ in conjunction with your recovery cds (windows xp installation CD and Windows Vista Recovery Disc)
My computer is getting constantly restart. If i acess any kind of program it get restart.
