Televison & Video Logo
Posted on Mar 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a Panasonic 1080P Plasma TV hooked up to BrightHouse Cable and a Blue Ray player. We use a Brighthouse remove to control all. We are trying to hook up a Panasonic DMR-E80H DVD Recorder. We are using composite cables. We cannot get the TV to recognize that the device is there. The ?geek squad? that installed all set us up to use the Brighthouse remote. Can we hook up both the BlueRay and the Recorder? We think we have to enter the device into the TV remote, but we?re scared to do much with it because we?re afraid we?ll screw up what the geek squad did to get the TV initially programmed into the Brighthouse remote. What exact steps do we need to do to get the recorder hooked up? Thanks.
Joseph Coppeto
Level 3:
Master:
  • Master 360 Answers
  • Posted on Mar 26, 2017
Joseph Coppeto
Master
Level 3:
Master:
Answers
360
Questions
0
Helped
149950
Points
2623
If your tv has inputs for many devices you can connect them. You need to simply change the tv input SOURCE to whatever #/type of input you want to view from.
You can use an y remote if programmed properly- that is another issue. programming the remote to control that deviovce but first see if it works right.
if the brighthouse remote can control the tv, change the input or source to whatever the dvd is in, other wise try the tv remote.
make it simple first, then you can try getting the one remote to control it IF it can.
my cable remote cannot control all my devices but does the tv.
5 Related Answers
Webfoot_Wa
Webfoot Washington
  • Posted on Oct 17, 2006
SOURCE: DMR E80H hard drive
DMR-E80H Hard drive problem seems to pretty common. My drive started making the famaous kerchunk noise tonight. After disassembly I see the drive is a ATA133 Maxtor drive....are you sure that you replaced it with the correct drive? I may contact Maxtor and try to get an RMA since the drive is only 3yrs old. Good Luck
Anonymous
  • Posted on Feb 05, 2008
SOURCE: Panasonic DMR-E80H Change Disc Error
If you haven't done so, try downloading the firmware update from their support site. Burn the update file to a cd-rom.
I have had numerous times where my unit recovered and I had to format the hard drive(losing all of my shows), but since I did the update this has not happened to me again.
Anonymous
  • Posted on Jan 24, 2009
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Anonymous
  • Posted on Jan 31, 2009
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Anonymous
  • Posted on Apr 11, 2009
SOURCE: Just hooked up Magnavox ZV457MG9 VCR/DVD
Hi - No, it isn't fixed yet. However, for some reason, if you will notice, at the top of this page in blue lettering, there is a reference to a "Toshiba, DVR........ . I did not notice that until after I had posted the request for help. The problem is with a new "Magnavox ZV457MG9" recorder/player. I would dearly love to find out how to fix the problem - I hate to give up - in fact I don't think I can give up! Hopefully, someone in your group will help shed some light on this! Thanks for checking, Ginny
Brighthouse remote code for lg 32 inch led tv
Here is a brighthouse code sheet for lg if you can read it. http://support.brighthouse.com/media/video/equipment/remotes/Remotes%20II/UR5.pdf
They make different remotes if this link does not help please provide which brighthouse remote you have.
Cant get brighthose remote to sync with dvd player
Do a code search with that remote control. For details, refer remote control's user manual.
I can't hook my mp3 to my Panasonic TV
Try to use a jack male to male cable and see if it works!
Programing codes for 40" uw40t3pw
I need the codes for my brighthouse cable remote. can anyone help?
I need the remote code to turn off my tv it is for brighthouse cable and vizio tv
What remote do you have? http://support.brighthouse.com/Article/User-Manual-Cable-Remote-Control-7379/
below is a list of remote's and the codes for a Vizio Tv.
If your remote is listed as NO CODE then you need to have your cable provider issue you a newer remote. most of the time its free.
Atlas - 0864, 0885, 1756
CLIKR-5 - 386 387
UR3-SR3S - 004 031
AT8400-D - NO CODE
AT8550 - NO CODE
AT2300 - NO CODE
AT8400 - NO CODE
BR-350 - NO CODE
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
1helpful
2answers
My brighthouse remote can turn my tv on and off but not change channels
The remotes have several device keys at the top of the remote. They have abbreviations like "VCR", "DVD", "TV", "CBL". By default some actions are locked into a specific key. By default, the volume buttons will always control the TV volume and the channel buttons will always change channels on a digital box.
If you have a digital box, and the channels wont change, the default locks might have been removed. Consult the instruction manual that came with the remote and re-lock the buttons to the correct device key. Otherwise you will need to press the "tv" button when trying to change volume and the "cbl" button when trying to change channels.
If you do NOT have a cable box and are just simply trying to use the universal remote as a primary remote, you will need to unlock the global channel lock. Consult the manual for the remote or check online for the remote guide. The Company which makes the remotes is called Universal Electronics and you can find digital copies of their manuals on the Brighthouse Websites.
We can't program the tv with the brighthouse cable
This is a brighthouse problem not a TV problem, if brighthouse won't help you just use the original or substitue remote.
The brighthouse remote may locate the correct frequency using the scan method ask them to send a remote book.
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
10helpful
3answers
Progamming code for DYNEX t.v. w/ brighthouse cable remote
Do what I did...
Turn on TV
Press TV on the remote(will blink once)
Press and hold setup until tv button blinks twice
Hit 991 tv key will blink twice
Aim remote at tv press power button once
Press the Chan + key over and over until tv shuts off.
Same instructions as the manual
Cable box-dvd/vcr- tv hookup problems
buy you one of those little boxes from like walmart,,that converts rca jacks to cable pugs ,,,there real cheap,,that will do it ,,in the electrinic isle,,
Universal cable company remote control codes
brighthouse remote code for panasonic amolifier to adjust volume
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
