Jensen Rock-N-Road GPS Logo
Posted on Nov 25, 2009
My husbands jensen nvx430bt is frozen on the screen with settings, blue tooth and multimedia on it and we can't return to the main screen and maps! HELP!!!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
314
Points
Any luck getting this fixed. Mine is in the same mode and I don't know what to do????
Looking for owners manual for gps NVX430BT
I have a pdf of the manual(s) for the Jensen GPS Model NVX430BT. Email: [email protected]
....Wayne.
Jan 21, 2010 • Jensen GPS
4helpful
Is there a way to get udateds for a jensen gps
i checked on this for u, no updates have been released, nor are there any going to be rleased in the near future.
Nov 13, 2009 • GPS
How do i get up dated maps for jensen nvx430bt
at this time there are no map updates avil for this GPS
Oct 16, 2009 • GPS
1helpful
Frozen Screen
Mine does this from time to time. I pull the SD map card, power it off, and hit the reset button while the unit is unplugged. These units are notorious for this. But then again, they're inexpensive. No receipt ... well, you're pretty much stuck with it. No receipt, no return or repair.
2answers
3helpful
Nvx430bt jensen gps initialization error no language files
Hi.
This happens when the language files stored in your Jensen's memory get damaged. The Sat Nav system will look for new language files on your USB memory, and return the error.
Often the problem happens because you formatted the disk.
I suggest to start trying to set language to English.
In theory you are supposed to restore the flash image from original CD or computer backup.
A first attempt to fix the problem can be done resetting the Sat Nav. Just take out the battery for ten seconds.
If you have the original CD, files to be restored are in the IGO folder, and must be copied into the flash disk.
Files to be copied are
  • igolaunch.exe
  • IGOPATH.TXT
  • SettingsBackup.ini
  • TAHOMA.TTF
  • TAHOMABD.TTF
If that does not work, contact Jensen/Audiovox clicking here, they will enable a download of the language files to replace the damaged ones.
4helpful
5answers
Jensen GPS NVX430BT How do I activate the text to speech ?
I'm about to return my Jensen NVX430BT because apparently the maps cannot be updated! The maps installed on the unit I just received are obviously outdated and there is no support from Jensen to get them updated. Too bad, this thing has it all except good directions.
Top Jensen GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Jensen GPS Expert? Answer questions, earn points and help others
