Washing Machines Logo
Anonymous Posted on Nov 25, 2009
Comes up with a readout of E40. m/c will not run
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
258
Points
I traced the fault to the door catch and I later founf out that the code E40 means a fault in the door locking system.
Just have to get my wife to push the door closed a little harder.
Thank you for your assistance with this problem.
Regards
Charlie
1helpful
What does error E40 mean
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
Tunturi E40 I'm free peddling , the speed stays at 0, the resistance stops, nevertheless the heartbeat is taken normally.
Dear Sir:
Please adjust the sensor speed , see the diagram below 2) Tigh the wires from the sensor speed 3) Run the sotware CALIBRATION very IMPORTANT! for easy diagnose and troubleshooting
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Can I use sdhc memory in my Optio E40? im getting conflicting answers .
The specifications in the manual state that you can use SDHC cards.
2helpful
Display comes up with e40 on the Zwf16581w zanussi washing machine
E40 is a common fault relating to the door switch,how old is your machine because that model was first made in 2007 until the present so it may be worth your while getting in touch with your dealer or Electrolux.The problem is that if you get a fault on the door switch you may well replace it and find all is ok but the original door fault could have caused damage to the main Programmer.
Good luck and I hope I helped.
14helpful
2answers
Electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
3helpful
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
4helpful
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
