The product displays an
0x ...
error code when printing (for example
Error: 0xf0af8004
). These error codes indicate that the product has an internal condition.
Solution
Use the instructions below to resolve the issue by restarting the product.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the
Insert Ink Cartridges
message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the
Power
button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
If this does not work, contact HP technical support for assistance.
There is a long list of websites that report this as true however most of these sites appear to be Christian based sites so bias in their reporting is very probable. Cerro Gordo Elementary school Google Search
You could have a bad network card. Print a configuration page and if it prints a second page with network information, then the card is good. If not, you need a new card.
The page is found under the information tab in the menus.
just load the disk into your computer. go to your My Computer Icon double click it. then double click the CD/DVDROM drive. then just follow the instructions.
I would Hold down the "Menu" and "Cancel" Button then for "Reset Printer" ,Turn Off the Printer remove the cartridges then reset them again. Along with the Drum Unit. Something is Not Seating properly start thier first. If I could be of further help or your in the CT area then contact us: http://www.copierspluswwllc.com
This is a common error code meaning that the printer does not understand a command. Redearch suggests that you try the following:
Be sure the printer does not go thru a power strip, but is plugged directly into the wall.
Check the printer cable, maybe swap it with another one.
Reseat the memory and formatter board.
Lengthen the power saver time to the maximum
Try printing from a different application
There have been cases where replacing the intermediate transfer belt has solved the problem.
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSIPERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
