Mitsubishi WD-65731 65" HDTV Logo
Posted on Jan 13, 2008
Red Status Light
I turn the power on and it tries to start. There is no picture and the fan runs a little bit. After about 30 seconds, the green timer light turns off and the red status light turns on. I've tried changing the bulb with the same results. When reset, the green light flashes and goes out but when re-powering, results are again the same. I've tried disconnecting from the power for several days, same problem. The owners manual said to take it to a service rep. I am hoping to avoid that cost and challenge. Any advise? Thanks.
Dan
  • Anonymous Mar 17, 2014
    green power light comes on, them after a couple of minutes the status loight turns red - no picture.
A
Anonymous
Hi we have a 52 inch mitsubishi high definition tv and ours did the same thing,we had a repair man out here and he said it was the engine in the tv which we never knew tv's had engines so i contacted mitsubishi cause we didn't take a entended warranty and told them that it was not even 3 yrs old and they should stand up to there products and they did they paid for the part which was 600 dollars and we had to pay for labor....we thought it was the light to and ordered one and it wasn't it was doing the same thing yours did .....
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_693301a25d57d47d
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Turned on TV and had no picture. Now when I reset I get green blinking light then solid green status. After about 30 seconded red lamp light comes on. Is there a solution?
Your lamp is defective, incorrectly installed, or the cooling fan under the lamp is not cooling the lamp for some reason. Service that area.
Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
13helpful
2answers
Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
2answers
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
