Hi I just want to play my lp's without going through the computer - but - I cant get any sound to come out of the inbuilt speakers? what am I doing wrong?
Sounds like a internal microphone issue in this case you will need a camera shop to have a look locally, But if your sure all the settings are correct nothing is muted then the problem is the internal microphone assembly inside. Let me know ether way.
Hi, DSC-S730 does not have inbuilt speaker to give sound in playback in camera, however, transfer movie clip in computer and playback it with Media Player to have sound as well. Thanks.
When doing this, you need to adjust your settings in the control panel for the audio. Usually it's defaulted to block sound when you plug in headphones. Make sure you are plugging them into the correct audio output, but it shouldn't play sound from both the headphones as well as the built in speakers.
First go to control panel, sounds and audio devices
go to the audio tab and make sure that your usb device is selected for audio playback
then, unconnect the headphones and restart your computer
after restarting, connect the headphones and Speakers , it should work
Digitizing sound does not improve its quality. If your LP's sound like they do when you just play them through a stereo then the sound card is doing its job, which is to reproduce audio. If you want to change the way it sounds look into software to buy to do so. But simply running it throuch a analog to digital converter will not make it sound better when your source is an LP
u need check u r sound setting click on sound icon on u r taskbar and then click on properties and playback or recording click on microphone and try to scroll lolz try dear
If your monitor have inbuilt speaker, then you need not to plug it, because the monitor cable will work for that. I have ViewSonic 19" with inbuilt speaker and its working without any extra cable or connection.
